February 07, 2026, 09:46:14 AM *
Author Topic: Picture needed of XF6 desmog  (Read 2719 times)
AZdougness
« on: July 07, 2013, 11:23:03 PM »
If anybody that has XF6's desmog kit and could post a close up of the plugs installed it would be greatly appreciated!
Cheers
Black Dog
VRCC # 7111
Merton Wisconsin 53029
« Reply #1 on: July 09, 2013, 11:06:01 AM »
No picture handy, but if you are talking about the larger plugs that go in the block, maybe I can help describe the fit.
They are tapered, more narrow at the bottom than top, and when 'lightly tapped' in, should be flush with the part of the block around the hole...
Hope that helps.
Black Dog
Don't you know...
Lastdragon
03 Black Standard, Yukon America
Yukon, Oklahoma
« Reply #2 on: July 09, 2013, 04:42:30 PM »
Here are a couple of pictures of mine
Ronnie Evans
Yukon, America
Member #17151
Farther
Quimper Peninsula, WA
« Reply #3 on: July 09, 2013, 04:49:07 PM »
Sweet, I have to do this.  I have had the F6X kit for about three years in my saddlebag.
~Farther
AZdougness
« Reply #4 on: July 10, 2013, 12:51:03 AM »
I have been having difficulties getting mine to seat properly. I presumed that the side with the very small point was the side that was intended to go in to the engine block, while the other completely flat side would be the "tapping" side. I unfortunately do not have a good caliper to find which is the tapered side. Did either of you have difficulties getting it flush? How hard is "lightly tapping" btw, hard enough to drive a nail into wood, or hard enough to drive a picture hanging nail into sheetrock...
Thanks again for your help.
« Reply #5 on: July 10, 2013, 06:19:12 AM »
You are correct, the end with the small point is the end that goes down.  The edge of the plug has a radius on it so it will be easier to drive into the 4 holes.  The top edge is sharp to fill up the hole to the edge so water/dirt/other stuff doesn't gather there.
The block off plates for the bottom are top notch.
I didn't have to tap mine too hard, but maybe harder than the picture frame nail into sheetrock.
Hay  Cool
Lastdragon
Yukon, Oklahoma
« Reply #6 on: July 10, 2013, 07:06:44 AM »
Hay  Cool
What Hayhauler said about tapping maybe harder than the picture frame nail. Everything in the XF6 kit worked as it should and it was a very clean installation.
« Last Edit: July 10, 2013, 07:08:55 AM by Lastdragon » Logged
Ronnie Evans
Yukon, America
Member #17151
Pappy!
Central Florida - Eustis
« Reply #7 on: July 10, 2013, 08:35:29 PM »
Darn, you guys! You just made me order one of the kits !!
Brian
Monroe, NC
« Reply #8 on: July 11, 2013, 02:52:07 AM »
WOW! This bike looks new. The XF6 desmog kit really does a great job of making the top plugs look like a factory finish. Makes me rethink the freeze plug method I started with. I suppose I could mix up more JB Weld to fill in the plug flush with the head to possibly achieve the same results. Nice job.
« Reply #9 on: July 11, 2013, 01:19:05 PM »
Man!!!  60 deg F oil temp??!!  I haven't seen that in over 6 months down here....  congrats!
Hay  Cool
« Reply #10 on: July 11, 2013, 04:11:05 PM »
Are you tapping the right end in 1st? My plugs from napa look like little bowls. Tap the contoured end in 1st and the cup part should be facing up. I just used a small socket to tap mine in.
Bugslayer
Lubbock, Texas
« Reply #11 on: July 11, 2013, 06:18:51 PM »
Who would I order the XF6 kit from?
« Reply #12 on: July 11, 2013, 06:38:10 PM »
http://xf6-custom.com/partpages/desmog.html
Used on both my bikes.  You can do it cheaper, but you can't do it better.
Bugslayer
Lubbock, Texas
« Reply #13 on: July 11, 2013, 07:42:19 PM »
Cool..... Thanks!
JimC
SE Wisconsin
« Reply #14 on: July 11, 2013, 07:44:32 PM »
I agree with that!
Jim
Jim Callaghan    SE Wisconsin
« Reply #15 on: July 11, 2013, 09:47:34 PM »
I thought the kit also included a couple Viton B vacuum (or other) lines that remain in place after complete desmog (petcock vacuum?) (don't see any in the kit picture).   I know I had them for use in the desmog, maybe they were from from elsewhere.  I got all desmog parts several years ago, and Big BF did the work for me last year, along with all intake gaskets large and small (and valves, carb synch, and petcock rebuilds, among other things).
Brian
Monroe, NC
« Reply #16 on: July 14, 2013, 05:18:32 AM »
The freeze plugs are tapered as is the port in the head. I tried the other way and it was cutting the sides of the port. I did not like how tight the 14mm plugs were going to be so I took a few thousands off by spinning it on a bench grinder. The exhaust pressure at this location should not be that high. If it was the air injection would not work without a pump. I could be wrong here, I have not had issues with the plug blowing out. The plug is sealed in place with JB Weld and two small chiseled dimples into the head.
BADNUF
Greenville SC
« Reply #17 on: August 01, 2013, 09:31:25 PM »
 Click on the shop talk old and new on the old tech board scroll down and there is desmog instructions with pics on behalh of Que express,Tim Skelton and Lamont hope this helps its what i used 3 yrs ago when i did mine it helped me out. Good luck.
Shiny side up and the rubber side down.
AZdougness
« Reply #18 on: August 02, 2013, 12:20:32 PM »
Thanks for the pictures Lastdragon, I realized I was just not tapping them in hard enough. I put aside the rubber mallet, picked up a ball-peen and worked them down flush.
Cheers
