November 25, 2025, 09:22:53 PM *
Author Topic: Bad Vibration  (Read 804 times)
BIG--T
The Twilight Zone
« on: July 22, 2013, 08:34:48 PM »
I have a 99 I/S with just 10k on her. I ran about 500 miles this weekend and halfway through I felt a bad vibration. I pulled over and checked my air pressure and it was ok. I didn't see a weight that come off or a knot and I feel it in the bars and all over. It has fairly new tires.
Thanks for any help on what to check.
« Last Edit: July 22, 2013, 08:45:43 PM by BIG--T » Logged
« Reply #1 on: July 22, 2013, 09:54:17 PM »
1st thing I'd do is get the front tire off the ground and rotate it looking for a rise in the tread.    If ya find nothing there do the rear.
Sounds like 1 of the 2 has got a baby in its belly.    You know a separation in the tread and tire body.
What kind of tires and what is the manufacture date on the tire?
Also, how many miles on them?
BIG--T
The Twilight Zone
« Reply #2 on: July 23, 2013, 05:20:49 AM »
Thanks RJ, I did a visual on the road but since I'm home now I'll jack it up and see. The tires are 880 Metz and only about 2500 miles, but I don't know the manufacturer date. Where do I look for the date?
« Last Edit: July 23, 2013, 12:25:39 PM by BIG--T » Logged
Earl in Pensacola
« Reply #3 on: July 23, 2013, 06:01:40 AM »
Could it be that you have two separate problems, one being the shifter and the other being the U-Joint???  First change the shifter back to the OEM and recheck for a viberation problem.  If it's gone, then you decide what you want to keep.  If it's still there, pull the rear tire off and drive shift out, check the U-joint for any looseness.  Lets us know what yo find.
BIG--T
The Twilight Zone
« Reply #4 on: July 23, 2013, 06:41:54 AM »
It could be and I'm checking one at a time starting with the wheels. I wouldn't think or hope it's not the u joint at only 10K miles and it's been babied- no popping clutches, burn outs, etc. Smiley
TGViper
« Reply #5 on: July 23, 2013, 07:55:30 AM »
Is the vibration under gear load only or does it happen rolling down the road when you pull the clutch in as well?
