February 07, 2026, 07:47:38 AM *
Author Topic: Anyone in Baton Rouge, LA area?  (Read 1286 times)
ragincajun
Atascocita, TX
« on: July 29, 2013, 08:42:02 AM »
Heading in from Texas, having a some starter issues. May need some help when I get into the Baton Rouge area Later today. Shoot me a PM if you might be able to help. Thanks in advance.
VRCC Member #34758
« Reply #1 on: July 29, 2013, 03:27:01 PM »
Can't be there, but what are the problems? Not many starters go out. It's most likely an old battery that won't hold a full charge. (Low Voltage)
ragincajun
Atascocita, TX
« Reply #2 on: July 29, 2013, 04:31:45 PM »
Push starts fine. Starter will not turn over. Headlight is gone out. I think it's due to no relay on the driving lights.
VRCC Member #34758
CajunRider
Broussard, LA
« Reply #3 on: July 29, 2013, 04:34:29 PM »
Sounds like a bad battery.
I'm in Lafayette with a good volt meter if you have time to stop by.
Unfortunately, I don't think I have a battery that'll work for ya... auto zone MAY have something that will work, but it'll be a lead acid that has to sit overnight (acid has to be put in batter after purchase).
Sent from my Apple IIe
trout dude
Hammond Louisiana
« Reply #4 on: July 29, 2013, 04:56:43 PM »
how long will you be in that area i live in mandeville la and could help you on tuesday
  Dennis
trout dude
Hammond Louisiana
« Reply #5 on: July 29, 2013, 04:59:16 PM »
Could be the starter switch my brother had same problem on his wing.
  Dennis
CajunRider
Broussard, LA
« Reply #6 on: July 29, 2013, 06:06:26 PM »
  Dennis
+1
Very true... and easy to check.  Definitely worth a look.
« Reply #7 on: July 29, 2013, 08:05:48 PM »
  Dennis
+1
That was my guess.  If it push starts, should be the starter switch.  He just had some driving lights wired in thru the low beam headlight.  No relay was used.
Hope it is the starter switch and gets fixed easily.
Hay Cool
Fudd
MSF RiderCoach
Denham Springs, La.
« Reply #8 on: July 29, 2013, 08:07:29 PM »
My bet is the starter button.
I've fixed a couple of them and can help out if you need me.
I'm 10 miles east of Baton Rouge.
Save a horse, ride a Valkyrie
ragincajun
Atascocita, TX
« Reply #9 on: July 30, 2013, 08:04:34 AM »
I'm thinking its the switch. Got referred to a mechanic that owns a Valk he's looking at it this morning.
VRCC Member #34758
Fudd
MSF RiderCoach
Denham Springs, La.
« Reply #10 on: July 30, 2013, 10:07:17 AM »
I'd do some wiring changes while you are at it.  Just from a redundancy aspect, I'd power the auxiliary lights from a different circuit.  That way, if you ever lose your headlight/starter switch circuit again, you'd still have forward lights to get you to a safe place to make repairs.
ragincajun
Atascocita, TX
« Reply #11 on: July 30, 2013, 06:59:19 PM »
Thanks to Marcus for spending some time on the phone last night walking me through a few things. Got hooked up with someone this morning and got the bike repaired. He put on a temporary starter switch and also put in a relay circuit for the lights to avoid that problem in the future.  Should be good to go for the time being. Will be having to get a new starter switch and replace that at some point but at least the relays in for the lights so that's a done deal.
Got back on the road this afternoon. Got down the river a good ways and ended up in Thibodeaux for the night. Will be heading back to the river for a while tomorrow before angling over to Morgan city tomorrow and then continuing on to the Delcambre area.
« Last Edit: April 18, 2014, 09:04:32 AM by ragincajun » Logged
VRCC Member #34758
« Reply #12 on: July 30, 2013, 08:59:09 PM »
Glad you got her going and back on your trip.  The relay is THE way to go.  Enjoy your ride!
Hay Cool
trout dude
Hammond Louisiana
« Reply #13 on: July 31, 2013, 04:22:16 AM »
Glad to hear your rolling again  cooldude
  Trout dude
LoBug504
S.E. Louisiana
« Reply #14 on: July 31, 2013, 02:00:20 PM »
  Dennis
Trout dude!!! I'm in Mandeville as well, right by the high school. Going to fire old girl and ride to work tomorrow. Works in Gramercy right now. Hope I see you around.
- Loring
Member #35021
cajunito
San Antonio,Texas
« Reply #15 on: July 31, 2013, 03:08:31 PM »
Good to hear `ya rolling! If you spend any time in Delcambre, eat some fresh swimps fer me!
