DarkSideR
Pueblo, Colorado
« on: August 01, 2013, 09:36:40 AM » |
Shifting has slowly gone from smooth to rough shifts. I suspect I have air in my clutch line. I have looked but haven't been able to find instructions on how to properly bleed the clutch. Can you please send me a document, or a link, or just list out step-by-step instructions?
2001 Valkyrie Super Tourer VRCC#34410 VRCCDS#0263
vanagon40
« Reply #1 on: August 01, 2013, 11:14:00 AM » |
You'll get a lot of different opinions on this subject. Some like to use a hand operated vacuum pump. Some use a hypodermic syringe to suck out the fluid, some use the syringe to pump in the fluid from the caliper up. Others install speed bleeders which is a bleeder with a check valve installed.
Simplest method with no fancy tools or equipment is to:
1. Remove the reservoir cover (being careful not to spill any fluid).
2. Attach a hose to bleeder and put the other end of the hose in a jar.
3. Open the bleeder valve (unscrew 1/4 to 1/2 turn).
4. Slowly squeeze the clutch lever to almost all the way and keep it squeezed in.
5. Close the bleeder valve (screw it back in).
6. Slowly release the clutch lever.
Repeats steps 3 to 6 until all the air is out of the line (or new, clean fluid is coming out the hose). Make sure to add fluid to the reservoir as necessary so the reservoir never runs dry.
7. Top off the fluid in the reservoir and replace the cap.
FOR GOOD MEASURE: Pull in the clutch lever, tie it to the handle bar, and let it set overnight.
Depending on your arm length and agility, bleeding the fluid in the above manner may be a two person job. It definitely is on an automobile.
GOOD LUCK.
DarkSideR
Pueblo, Colorado
« Reply #2 on: August 01, 2013, 11:16:09 AM » |
This is where I am failing. Where is the bleeder valve?
vanagon40
« Reply #3 on: August 01, 2013, 11:22:54 AM » |
Ignore the added air horn. Looking at the petcock, the bleeder valve is just below 5:00 o'clock. Sticking up at a 45° angle pointing to the front. Has a little black rubber cap in it.
whitestroke
« Reply #4 on: August 01, 2013, 11:49:37 AM » |
If you use a use a hand operated vacuum pump does it matter if the clutch lever is pulled in or out?
Minibike Honda S90 Yamaha YL100 Bultaco 250 Matador Bultaco 250 Pursang Yamaha 250 YZ Triumph 650 Bonni Honda ATC 200
2 Kids 25 year break. Suzuki GS 500 2003 VTX 1300S, 1998 Valk standard 2008 Goldwing
« Reply #5 on: August 01, 2013, 02:27:23 PM » |
No it doesn't matter. Although operating the lever moves all the old fluid out of the cylinder into the line where it'll get flushed.
Dorkman
« Reply #6 on: August 01, 2013, 03:37:31 PM » |
If you use a hand operated vacuum pump, the manual method, or inserting syringe from below, be sure to use 5/32" ID clear tubing to get a tight fit on the bleed valve. Once air gets in the system, you will go nuts.
If you go the speed bleeder route, 1/8" ID clear tubing fits nice and tight on the speed bleeders. I found the vacuum pump to be awkward to use...but that's just me. Install speed bleeders once, clutch and brakes, good to go for now and future.
Many posts mention turning handle bars to right, loosen and tilt upward, loosen clutch res to get it level. Cover tank with towel. Zip tie clutch lever overnight or longer lets any bubble rise. Tap round banjo bolt with rubber mallet to encourage bubbles to move. All good info.
DarkSideR
Pueblo, Colorado
« Reply #7 on: August 02, 2013, 06:30:33 PM » |
Well I did it. I replaced the clutch fluid. Doesn't shift any smoother  Anyway thank you for your help here.
Whooray
Idaho State Rep
Kuna, Idaho
« Reply #8 on: August 03, 2013, 05:29:06 AM » |
Joshcornkid, we met at Misfits at the get together.....some riders find that the shifting is smoother using different brands, weights of oil. Seems to make a big difference to some. Raymond
Vietnam Vet 6/68 - 1/70 919th Combat Engineers 11th ACR (Blackhorse)
