November 25, 2025, 09:27:42 PM *
Author Topic: radiantz brake module question  (Read 985 times)
al v
Clinton Township, MI
« on: August 06, 2013, 07:05:56 PM »
Anyone using the strobe flash mode of the radiantz brake module or similar brake module? (Instead of just the standard flash mode)
Strobe mode when combined with a radiantz led taillight seems like way to much.
If anyone has tried it, any problems with drivers behind you not liking it?
Highly recommend the radiantz led taillight by the way, it is way brighter than the stock bulb with the same red lens cover.
sheets
Jct Rte 299 & 96, Calif.
« Reply #1 on: August 06, 2013, 07:23:53 PM »
I ran a Radiantz tail light for years with a blinking (forget brand name) device wired in. Nary a problem. Numerous occasions over the years had a motorist pull up along side at a signal to let me know my brake light was blinking. That was the assurance I needed to know how effective the combination was. Some states have vehicle codes defining the use and sequence of blinking brake lights. Ya may want to verify and clarify. Its a good set up and worked for me.
mmvalk
Boynton Beach, FL
« Reply #2 on: August 07, 2013, 01:51:12 AM »
I use Radiantz and a Whelan TR6 and the combination is really effective - bright and noticeable!  Highly recommended!
Mr.BubblesVRCCDS0008
« Reply #3 on: August 09, 2013, 03:41:08 AM »
I use a night rider light from Custom Dynamics
