November 25, 2025, 09:27:17 PM *
Author Topic: Oil Filter Question  (Read 1890 times)
Gideon
Indianapolis, IN.
« on: August 09, 2013, 03:33:24 PM »
Has anyone ever been told not to use a PL14610 Purolator Oil Filter when using Synthetic Oil ???
Today I went to Advance Auto Store to Get a PL14610. In talking with the clerk behind the counter I told him I used  Synthetic Oil. He stated that for synthetic oils I must refer to the Purolator Synthetic Oil Filters (Part No. PSL30001). Shocked
quexpress
Montreal, Québec, Canada
« Reply #1 on: August 09, 2013, 03:56:00 PM »
Another Einstein behind the counter ...  uglystupid2 I thought that they were all in my neck of the woods!  Roll Eyes
It seems to me that "filters are designed to properly filter the microscopic particles from engine oil whether it is synthetic or traditional motor oil".
"What matters when replacing a filter? How well the filter does its job – get one with a filtration rate that’s the same, or better, than the filter" you have been using.
If you wish, there is interesting discussion at:
http://www.bobistheoilguy.com/forums/ubbthreads.php?ubb=showflat&Number=2550123&page=1  cooldude
I still have a full deck.
I just shuffle slower ...
Len
« Reply #2 on: August 09, 2013, 06:11:40 PM »
I have not had an  issue with the Valk and I use the K&N filter, but Sears will charge extra for a different filer when using synthetic oil in car/truck engines. I have used the same filter on my bikes and I use synthetic oil in all of them...a filter will/should do the same job regardless of the oil type.
Yes, I am using the same K&N filter with Mobil1 10w-40 motorcycle oil in my Valk...same as my three other bikes.  I will try the purolator filter number you asked about on my next Valkyrie oil change...my .03 cents.
« Reply #3 on: August 09, 2013, 08:10:38 PM »
Synthetic oil doesn't require a special filter.
« Reply #4 on: August 09, 2013, 10:33:45 PM »
Dat clerk is trying to sell you a higher priced filter.
Now, open your mouth and exhale as hard as ya can, cause he is just blowing smoke up your ass.
« Reply #5 on: August 10, 2013, 05:09:25 AM »
most auto counter people today are a little smarter than the dirt on your boot.
the filter media is of a synthetic material which means it is not paper based. it is not for syn oil.
There are a few oil and industrial machinery trade industry articles about how the syn media oil filters actually increase the varnish levels in the oil and onto the engine parts. varnish is very, very bad.
I would stay with a Pure One paper filter. I use an oversized one PL14459
« Reply #6 on: August 10, 2013, 06:26:01 AM »
Ditto what everyone else has said, however, there's also been some debate that the use of the PL14510 or the PL14612 can cause oil pressure and oil pump problems.
Perhaps that's what he was referring to.
From Purolator's site.....
"Because of PureONE's high efficiency, the motorcycle oil pump may not be able to handle the pressure."
That said, people have been using them on Valks and Goldwings for years and years and miles and miles with zero problems.  What most people don't seem to remember is that the Valk and Goldwing motor is basically a car engine with a suitable oil pump....they're not your typical motorcycle engine.  They can handle the PL14610/PL14612 just fine.  It's what I use.....that and Mobil 1 V-Twin 20W-50 motorcycle oil.   Wink
« Last Edit: August 10, 2013, 06:28:16 AM by BF » Logged
« Reply #7 on: August 10, 2013, 06:34:20 AM »
That's a good one I'm going to have to remember.  It applies to whole categories beyond auto counter people.
Disco
Republic of Texas
« Reply #8 on: August 10, 2013, 06:47:48 AM »
I have roughly 70K miles on PL14610 filters + (Royal Purple, Mobil 1, Rotella T).
22 CRF450RL, 19 BMW R1250RT
78 CB550K
71 Suzuki MT50 Trailhopper
Gideon
Indianapolis, IN.
« Reply #9 on: August 10, 2013, 02:45:22 PM »
I want to thank all of you for replying.  Smiley
I will continue to use the PL14610 filter with Rotella T Synthetic. cooldude
The Bob the oil guy forum was interesting. Smiley
Thanks again.
john
tyler texas
« Reply #10 on: August 10, 2013, 10:15:35 PM »
 " the lack of bypass valve on this filter makes me hesitant to throw $10 in the trash "            ???             Undecided                   tickedoff
                 no bueno       coolsmiley
« Last Edit: August 10, 2013, 10:22:03 PM by john » Logged
vrcc # 19002
« Reply #11 on: August 11, 2013, 03:56:25 AM »
  What most people don't seem to remember is that the Valk and Goldwing motor is basically a car engine with a suitable oil pump....they're not your typical motorcycle engine.  [/quote]
I've seen this posted before, what a load of.........
what car engine has a shared transmission?
motorcycles have been using boxer style engines way before cars started using them.
the valk/GW engine main oil pump maxes out at 70 psi approx.
BIG--T
The Twilight Zone
« Reply #12 on: August 11, 2013, 06:38:52 AM »
Like CA said "most auto counter people today are a little smarter than the dirt on your boot"- If you take away their computer they are LOST!!  Grin  I run that same filter in both my Valk and VTX and they're still running good! sometimes I will switch to Mobil or Bosch with the specials. cooldude
CB1
DFW, TX
« Reply #13 on: August 11, 2013, 01:14:20 PM »
Agreed!! Both to the Filter and the Oil!!
Thanks!
Chris
F6Dave
« Reply #14 on: August 11, 2013, 07:56:47 PM »
Think about this for a second.  In a motorcycle, the oil has to lubricate the transmission as well as the engine.  Many motorcycle engines rev to well over 10,000 RPM.  Some even rev above 15,000 and have piston speeds close to those seen in F1 engines.  With engines like that I can't imagine a manufacturer using some cheap oil pump.  Maybe whoever wrote that line on the website hasn't paid attention to the advances in motorcycles over the last several decades.
