November 25, 2025, 09:27:18 PM
brake fluid/clutch fluid
Topic: brake fluid/clutch fluid (Read 985 times)
slider
mulberry arkansas
August 10, 2013, 08:33:08 AM »
yesterday noticed a few drops of brake fluid under the clutch housing of the lady,the clutch resv was a bit low as well.The clutch cover bolts were about 1/2 turn loose all the way around.,the question is would this cause the leak or should I think about replacing the slave cylinder for the clutch?It is the original clutch and works great and I assume slave is original as well.It has never been low before and the fluid is flushed everyother year.Any input from you is welcome.
a proud navy veteran
vanagon40
Greenwood, IN
Re: brake fluid/clutch fluid
August 10, 2013, 09:00:53 AM »
You might send a PM to Squealy. He just had a similar ordeal. See
this thread
August 10, 2013, 10:04:42 AM »
It really shouldn't leak, unless, its loose enough to put enough side stress on it to allow fluid past the the seal. I think I would just tighten it up, add fluid if needed, maybe bleed it and then run it to see what happens.
August 11, 2013, 07:07:54 AM »
If the clutch cover (housing) were loose, you would be seeing motor oil, not brake fluid.
9Ball
August 11, 2013, 03:52:57 PM »
I'd imagine he was referring to the clutch master cylinder cover...different animal.
Just a guess.
VRCC #6897, Joined May, 2000
1999 Standard
2007 Rocket 3
2005 VTX 1300S
slider
mulberry arkansas
August 12, 2013, 07:17:14 AM »
sorry guys it was the clutch master that I was refering to since I tightened it up it havent seen anything else leaking,,problem solved I hope.Thanks to all of you.
=> InZane XXV
