February 07, 2026, 11:32:15 AM
exhaust pipes
Topic: exhaust pipes (Read 1108 times)
baffled
exhaust pipes
August 13, 2013, 09:02:58 PM »
98 standard , left side pipes turning a yellowish color.would appreciate info on what to do to fix the problem. THANKS
9Ball
Re: exhaust pipes
August 14, 2013, 05:05:29 AM »
I don't know what happened to the original post and responses and assuming you are asking about stock pipes...
Riding with the enricheners engaged or allowing the bike to idle too long while sitting such as starting it up in the garage and not actually riding will cause this condition. I've seen pipes also go from yellow to brown due to either of these practices.
Don't just start the bike and let it sit idling for extended periods.
I would check that the enricheners aren't sticking on the left side carbs. You can check this by moving the choke lever and observing that the enricheners move in and out freely.
Good luck...
Last Edit: August 14, 2013, 05:08:18 AM by 9Ball
VRCC #6897, Joined May, 2000
1999 Standard
2007 Rocket 3
2005 VTX 1300S
Re: exhaust pipes
August 14, 2013, 05:26:17 AM »
too rich causes those colors, too lean will cause the blue colors
