January 29, 2026, 02:13:27 AM
Sudden drop in fuel mileage
Topic: Sudden drop in fuel mileage (Read 2199 times)
Mondo Limbo
July 10, 2009, 06:05:48 AM »
Just in the last few weeks my gas mileage has dropped dramatically on my 02 Valk. I usually get 31 - 33 mpg in town or at 70+, or 35 - 37 cruising at 50 - 65 or so, but suddenly I've dropped to about 25 - 26 mpg all the time. I found a broken vacuum hose and repaired it, but no change. Can anyone give me some ideas? I just recently put in new plugs, and run some carb cleaner in the gas once in a while. I have a K&N air filter, 6 into 6 pippes, and a Dyna 3000 on setting 4.
Bone
Re: Sudden drop in fuel mileage
July 10, 2009, 06:48:11 AM »
Why did the hose break ? If it was from age all of the hoses are in the same condition and need changing. You say you repaired the break, are you sure ?
Replacement is the best action for the hose.
July 10, 2009, 09:44:54 AM »
Sounds like you got a serious vacuum leak.
I'd change all those little hoses on the carbs and into the 'T' fittings and etc.
I change mine out about every 2 or 3 years......
July 10, 2009, 09:46:56 AM »
You ought to go ahead and do a complete de-smog. Never have to worry about bad hoses anymore. Add a Pingle to get rid of the #6 hose.
July 10, 2009, 09:55:36 AM »
I would check the fuel valve the valve can leak and not look as though anything is wrong,also putting the dyna to setting 7 would help
Mondo Limbo
July 10, 2009, 10:29:34 AM »
Is there a link somewhere on how to do the total de-smog? Other than that I guess I need to dig in and check all the hoses I can find. The one I found was broken right where it made a sharp bend onto the fitting.
I was just wondering what else I should check? Other than the vacuum hoses I'm guessing have the carbs checked and syched and maybe the valves adjusted. The thing is - it runs great, just the mileage is dropping.
Bone
Reply #6 on:
July 10, 2009, 11:41:47 AM »
Scroll up and you will see Shoptalk, lot of good info.
http://www.valkyrieriders.com/shoptalk/desmog.htm
