April 29, 2026, 12:30:16 PM *
Author Topic: Anyone know of any farm salvage around cent Fl?  (Read 7887 times)
Jeff K
« on: August 22, 2013, 10:24:55 AM »
Trying to find a 24" plow disc for a cooker i want to build. Not having any luck finding a disc.
Bert AKA,Valkaholic
Back-N-Black
« Reply #1 on: August 22, 2013, 10:41:19 AM »
If all else fails,you may be able to buy a new blade at Tractor Supply.
Jeff K
« Reply #2 on: August 22, 2013, 10:57:31 AM »
They looked at me like I was asking for unicorns. Like they had no idea what one was
Grumpy
Tampa, Fl
« Reply #3 on: August 22, 2013, 01:27:51 PM »
Give this place a try, here is a link to the catalog for disc parts.
http://www.dmtractorparts.com/catalog.php#c239
Jeff K
« Reply #4 on: August 22, 2013, 01:39:41 PM »
Holy crap! $80???  Shocked
« Reply #5 on: August 22, 2013, 02:36:36 PM »
http://www.dmtractorparts.com/catalog.php#m0c239p61175
This one is 18" and $29.XX
Hay  Cool
Jeff K
« Reply #6 on: August 22, 2013, 02:54:15 PM »
Yeah, I saw that one, I want a 24 at the smallest.
http://mower-blades.agrisupply.com/search#?p=Q&lbc=agrisupply&uid=81917966&ts=ajax&w=24%22%20disc&isort=score&method=and&view=grid&stateid=s2C12B12C1JzR04an2&modaf=r:cat:6
But shipping would kill me
Jeff K
« Reply #7 on: August 22, 2013, 03:16:10 PM »
I figured with all of us craving up the rural twistys of central Florida surely someone would point out a few acres of used farm equipment.   Sad
Bert AKA,Valkaholic
Back-N-Black
« Reply #8 on: August 22, 2013, 03:57:16 PM »
Weeks Auction on S.R. 40 in Ocala sells used Equipment and New Implements but I do not know if they have a Single 24" Disc Blade for sale .If you had of needed one twelve years ago I could have gotten all of them that you want but I no longer have that Connection.If I run across one in my travels around Ocala I will let you know.
F6MoRider
Lakeland, FL
« Reply #9 on: August 22, 2013, 04:55:41 PM »
There is a place on the SW corner of I-4 and US 75 that has farm implements piled near the fence facing 75 with "For Sale" signs on the stuff.  I bought a 6' blade from him a number of years back and back them he had a yard full of different odds and ends.  I recall a few cutaways and other parts laying around.  You may want to take a look and see if the number is still up on the fence or take the next exit south and find your way back in from the secondary road.
VRCC #4086
2000 Valk Standard dressed with matching Interstate Bags and the Hondaline shield.
Grumpy
Tampa, Fl
« Reply #10 on: August 22, 2013, 05:14:54 PM »
I know that place, about 1/4 mile from me. If you get off I-4 at 579, go south to the intersection of US92, turn right. Then go west about 1 1/2 mile to Williams rd turn right again, you cross over I-4 and it is the first drive on the right. Sits down in a low place, all kinds of critters there. If you are not in a big rush, I will stop by and see what he has.
Jeff K
« Reply #11 on: August 22, 2013, 05:16:15 PM »
i google earthed it and could actually see the sign!  cooldude
Called him, and he said he had 3 of them. 2 were on a watermelon plow and one was just mounted to a plate... how much? $100...  Shocked   for one of them!  Cry
Well it was a good lead. Thanks
F6MoRider
Lakeland, FL
« Reply #12 on: August 22, 2013, 06:32:02 PM »
[/quote]
Hey Grumpy...if you know the guy at this place, maybe you can stop in and see if a better price is available?  100 bucks for a single disk blade sounds a little pricey?
Also, if you know someone who can straighten the L steel frame on a cutaway, share the contact details with me please.  My pops backed the tractor into a tree and bent the support frame on the cutaway and I can't find a shop with a press or a frame strong enough to set the support frame on to get leverage to either bend the end back up or push the hump down and flatten the arm out so it's level again!
VRCC #4086
Grumpy
Tampa, Fl
« Reply #13 on: August 22, 2013, 06:36:26 PM »
[/quote]I do not know him personally, just drive by it all the time. I will stop there Sat and see what he has.
« Last Edit: August 22, 2013, 06:38:23 PM by Grumpy » Logged
flsix
« Reply #14 on: August 23, 2013, 03:55:19 PM »
Jeff, where do you live?
I work at a large farm near Immokalee, that's in the Naples area. We rebuild our discs about once a year. Right now we are running 5 of them. I think there are some used blades in the scrap pile. I'll check if tomorrow and give you and answer.
   Jeff
2013 F6B
           ESCHEW OBFUSCATION
Jeff K
« Reply #15 on: August 23, 2013, 05:22:46 PM »
Great!
Grumpy
Tampa, Fl
« Reply #16 on: August 23, 2013, 05:51:57 PM »
[/quote]I stopped by the place this afternoon, only thing he has right now is a wore out ford tractor for sale. No Joy on a disk.
Jeff K
« Reply #17 on: August 23, 2013, 06:21:42 PM »
Thanks for looking!
Jeff K
flsix
« Reply #18 on: August 24, 2013, 02:45:28 PM »
Jeff, I'm not sure what you are using the blade for other than a cooker.
I have an old one that is just over 24", but being used it's very thin and sharp on the edge. (think sharp enough to slice the tip of the sole of your boot if you spin the gang with your foot). You may want to trim or grind the edge if you are planing to weld along the edge.
On the other hand I also have a scalloped edge blade that is about 30" in dia. on the outside. At the bottom of the scallops it's 26". It's at least a 3" deep dish. It is about 40# and never used but still rusty from sitting around for about 8 years.
You are welcome to either one or both if you need them.
I'm going to be in Lakeland on the 21st. of Sept. for a gun show if that helps with picking it up.
Let me know what you are thinking.
Give a call if you want. My cell number is 239-six four one-5772
   Jeff
2013 F6B
           ESCHEW OBFUSCATION
Jeff K
« Reply #19 on: August 24, 2013, 05:05:16 PM »
I will be at the same gun show. So we could meet then. Depending on how thin thin is... Either is fine.
Yes making a Cowboy Wok
flsix
« Reply #20 on: August 25, 2013, 02:41:56 AM »
I've made probably 10 of those over the years. I have used the 24" blades with good results. They are great for fish fries.  cooldude
If I needed a little more depth in one I have added a narrow strip of flat bar welded on edge around the outside. A 1" long piece of 8" pipe works well for a base when welded to the bottom of the disc. If you like I'll cut you a piece of 8 or 10" pipe and bring it along.
Keep my cell number and call me a week before the show just to remind me to bring the stuff up and I'll see you there.
   Jeff
2013 F6B
           ESCHEW OBFUSCATION
Jeff K
« Reply #21 on: August 25, 2013, 09:20:48 AM »
Good deal. Thanks
 Grin
FloridaValkRyder
Apopka, Florida
« Reply #22 on: August 25, 2013, 03:43:21 PM »
Jeff and Jeff,
We have a lot of Jeff's here now don't we, probably raising the bar a little I'm sure... Wink
Jeff
I still miss her.
flsix
« Reply #23 on: August 26, 2013, 02:31:06 AM »
If we treated it like a disease we could set up a benefit ride for being a Jeff and take in enough donations for some new chrome doodads for the phat gurls. 2funny
2013 F6B
           ESCHEW OBFUSCATION
FloridaValkRyder
Apopka, Florida
« Reply #24 on: August 26, 2013, 08:08:07 AM »
Now your talking!!  cooldude
I still miss her.
flsix
« Reply #25 on: September 12, 2013, 04:40:46 PM »
Hey Jeff, after looking around in the back yard today I found an almost new (but rusty) 26" blade. Would you rather have that? If it were me I'd use it instead of the 24".
Are you still planning on going to the show?
   Jeff
2013 F6B
           ESCHEW OBFUSCATION
Jeff K
« Reply #26 on: September 12, 2013, 06:03:26 PM »
26 is exactly what I was looking for!
Yes, we will be going to the show.
Jeff K
« Reply #27 on: September 19, 2013, 06:16:53 PM »
   Jeff
Any Idea when you want to meet?
flsix
« Reply #28 on: September 20, 2013, 03:58:19 AM »
We won't get there until 9:30.
Give me a call then and we can meet in the parking lot.
I don't think you want to strap this to your bike though Shocked
Number is 239 six four 1 five 77 two.  See you there.
Jeff
2013 F6B
           ESCHEW OBFUSCATION
Jeff K
« Reply #29 on: September 20, 2013, 03:29:39 PM »
Jeff
I'm going to be bringing my tribe and though my granddaughter loves riding, my newly acquired grandson (son just got married) will not get on a bike. So I will be in my truck. I planned on just bringing my bike and trailer, but looks like the Ford instead.
Jeff
flsix
« Reply #30 on: September 21, 2013, 02:27:53 AM »
Will be heading that way in less than an hour.
2013 F6B
           ESCHEW OBFUSCATION
Jeff K
« Reply #31 on: September 21, 2013, 09:35:53 AM »
Thanks Jeff. It was good meeting you.
flsix
« Reply #32 on: September 22, 2013, 04:18:57 AM »
Good luck with the frier Jeff.
2013 F6B
           ESCHEW OBFUSCATION
Jeff K
« Reply #33 on: September 28, 2013, 05:47:42 PM »
Thanks Jeff!
Jeff K
« Reply #34 on: September 28, 2013, 05:49:34 PM »
Fajitas were awesome!!!
flsix
« Reply #35 on: September 28, 2013, 07:16:07 PM »
It looks great. Glad you like it.
If you use it as a deep frier with an inch or so of oil in it, I found that the fish or fries slide back into the oil while draining on the edge. To stop that from happening I built up some spot welds with the wire machine about one inch in from the edge of the blade. There're about a quarter inch high and may be four inches apart. Have one with the spot welds and one without.
Eat well. cooldude
2013 F6B
           ESCHEW OBFUSCATION
FloridaValkRyder
Apopka, Florida
« Reply #36 on: September 29, 2013, 06:12:17 AM »
What a neat idea Jeff. I bet those handles on the top get pretty hot.
I still miss her.
Jeff K
« Reply #37 on: September 29, 2013, 11:03:05 AM »
The handles don't get too hot. I can pick it up. Thanks to Jeff for the flame distribution idea, the parts!
Jeff K
« Reply #38 on: November 02, 2013, 06:30:04 PM »
Working on a cart. Not done yet, but you get the idea...
« Last Edit: November 02, 2013, 06:50:56 PM by Jeff K » Logged
OnaWingandaPrayer
« Reply #39 on: November 02, 2013, 06:38:31 PM »
 Thats a nice piece of work . Enjoy the good times .
