February 07, 2026, 01:14:52 PM *
Author Topic: Do you know what is it for?  (Read 1380 times)
frenteacasa
Madrid, Spain
« on: August 24, 2013, 01:20:41 AM »
Hi all,
I worked today on the bike and changed the air filter (I removed the tank and the seat). A rubber block dropped (unfortunately I missed it, but is something like this one. Size is about 3/4" x 1 1/2"). Do you know what is it for and where it is placed??:
I discovered also a rubber hose broken an disconnected (red colour on the picture).
I assume it has been like that for some time. What is it for? Should I replace it urgently?
Thanks a lot in advance!!
fordmano
San Jose, CA.
« Reply #1 on: August 24, 2013, 02:34:09 AM »
First item probably a rubber bumper off the underside of the seat pan?
Second item is just a drain hose for the carburetor bowl, no worries with it like that unless you need to drain the carb bowl...
Next?
83GS550
93XR650L TARD!
97WR250
99ValkyrieI/S Tri-tone
01YZ125(x2)
05DRZ-125
fordmano
San Jose, CA.
« Reply #2 on: August 24, 2013, 02:35:35 AM »
Edit: if that rubber block has a large diameter hole in it them it might be the cushion/bumper at the rear of the tank where it sits on the frame in front of the seat.
83GS550
93XR650L TARD!
97WR250
01YZ125(x2)
05DRZ-125
frenteacasa
Madrid, Spain
« Reply #3 on: August 24, 2013, 03:13:53 AM »
Thanks a lot fordmano  cooldude. There is no hole in the rubber block, so I assume is under the seat...
Bert AKA,Valkaholic
Back-N-Black
« Reply #4 on: August 24, 2013, 03:15:37 PM »
You may want to take a look at all of those small Vacuum lines,if one is rotten then there may be more like it under there.When they dry rot and crack it can make the bike pop or backfire when you release the throttle while slowing down.If the one that goes to the petcock has cracks or damage it may stop the fuel from flowing to the Carb's. It looks like it is time to spend three or four dollars on Vacuum line.
quexpress
Montreal, Québec, Canada
« Reply #5 on: August 24, 2013, 08:06:21 PM »
Hi all,
Look at the back of your radiator reserve tank. I seem to remember seeing it there ... but I could be wrong.  Smiley
I still have a full deck.
I just shuffle slower ...
frenteacasa
Madrid, Spain
« Reply #6 on: August 25, 2013, 02:03:03 AM »
I checked it and.... you are right!!!. It was the block at the back of the coolant tank cooldude cooldude cooldude
quexpress
« Reply #7 on: August 28, 2013, 05:28:28 AM »
