February 07, 2026, 01:14:49 PM *
Author Topic: Key turned on, no headlight then . . .  (Read 1054 times)
Kunkies
Charlotte, NC
« on: August 26, 2013, 04:19:21 AM »
. . . I start her up and the head light comes to life.  Starter switch?
Michvalk
Remus, Mi
« Reply #1 on: August 26, 2013, 05:26:52 AM »
My first guess would be the switch. Could be a bad bulb too cooldude
hager the horrible
florence co
« Reply #2 on: August 26, 2013, 11:20:14 AM »
Check fuse link under right side cover
Moonshot_1
« Reply #3 on: August 26, 2013, 03:48:32 PM »
I'd pick the starter switch. Wiggle it around (gently) and see if the headlight goes off and on.
Mike Luken
Cherokee, Ia.
Kunkies
Charlotte, NC
« Reply #4 on: August 27, 2013, 03:36:07 AM »
Good advice.  I doubt it's the bulb for I replaced it less than 6-7 months ago.  I'll wiggle the starter switch next time I turn the key and see if the headlight comes back to life.
Michvalk
Remus, Mi
« Reply #5 on: August 27, 2013, 04:35:04 AM »
I've had new bulbs go bad the same day they were installed. Don't discount the possibility. I would keep that in mind as I went through the rest of the stuff. Don't forget to check the high/low switch as well cooldude
hager the horrible
florence co
« Reply #6 on: August 27, 2013, 04:51:22 AM »
Why would you consider bulbs? He says headlight comes on after he starts it up
Michvalk
Remus, Mi
« Reply #7 on: August 27, 2013, 03:51:51 PM »
I've had bulbs that broke the filament and would not touch and light up until a bit after power was switched on, or after riding out. Just throwing out possibilities cooldude
