November 25, 2025, 09:57:47 PM *
Author Topic: Question regarding adding triple tips tò interstate.  (Read 1574 times)
Cliff
Manchester, NH
« on: September 07, 2013, 08:57:46 AM »
When adding the triple tips to the Interstate will I need to make any mods?
« Last Edit: September 08, 2013, 05:40:38 AM by Cliff » Logged
VRCC # 29680
« Reply #1 on: September 07, 2013, 04:07:01 PM »
Cliff;
I own Tourers, so I have no experience with a Interstate, but I believe the triple tips should just bolt on.
BonS
Blue Springs, MO
« Reply #2 on: September 07, 2013, 04:14:00 PM »
No mods needed. But I think that you can only use two of the mounting screws rather than all three. It was not a problem while I had them installed.
Cliff
Manchester, NH
« Reply #3 on: September 08, 2013, 05:41:40 AM »
Thanks for the info ! cooldude
VRCC # 29680
Pete
« Reply #4 on: September 08, 2013, 07:20:11 AM »
The piggies will interfere with the triple tips and require shorting and/or bending.
The heat shields on the bags may also interfere at the back where they dip down.
You may consider raising the bags and heat shield by 3/8 inch or reshaping the heat shield if there is enough room.
Let us know how it works out.
BonS
Blue Springs, MO
« Reply #5 on: September 08, 2013, 07:52:18 AM »
I stand corrected. I had my piggies cut while I had the triple tips. However, I didn't bend or adjust my bag supports and didn't have a problem with installation (that I recall).
Garland
#618
Hendersonville NC
« Reply #6 on: September 08, 2013, 11:01:10 AM »
I have a Tourer, with Interstate exhaust, with triple tips. I had to cut the piggies to install.
KSDragonRider
Salina, KS
« Reply #7 on: September 08, 2013, 05:41:26 PM »
I also had to cut the piggies to install the triple tips on an interstate.
I really love the look of them though!
Dalen & Shay -> Salina, KS
VRCC Member #33950
Cliff
Manchester, NH
« Reply #8 on: September 12, 2013, 12:49:45 PM »
Triple tips arrived today.   Yep...  looks like 3-4 inches needs to be cut from each piggie.  You guys that did this before.... did you notice an increase in sound levels? (Droning)
VRCC # 29680
« Reply #9 on: September 12, 2013, 12:59:02 PM »
I don't know that you'll get droning, but it will be louder.
Interstate exhausts were the quietest I've had... Tourer exhaust with triple-tips - the loudest.
The trimming of the Interstate piggies will increase sound, and the triple-tips themselves
increase sound. With Interstate or Tourer tips, the piggies pretty much come to the end.
With triple-tips, the piggies end back inside the tips, I guess the sound gets to bounce
around inside the tip more - but my triple-tips don't induce droning the way that normal
tips with way-cut-off piggies do.
Cliff
Manchester, NH
« Reply #10 on: September 13, 2013, 07:16:26 PM »
Managed to get them mounted without cutting piggies. . Creative piggie bending  cooldude
VRCC # 29680
