January 29, 2026, 03:36:44 AM *
Author Topic: Replacing locksets  (Read 2513 times)
Sharkey
GOT CURVES??
VRCCDS0184
« on: July 12, 2009, 06:06:43 PM »
My ignition was giving me trouble, and I put in a new key with sharp edges and pulled the guts out of it.
 I went ahead and ordered a new lockset from HDL, How difficult is it to get the tumblers out of the tree ,tank, and seat release. It should be delivered Wednesday.
« Reply #1 on: July 12, 2009, 06:27:08 PM »
I got a new lock set for my Tourer from HDL. I haven't installed any of the parts yet, but
mine came with a whole new gas cap, that part should be easy. I don't look forward to
fumbling around with the seat lock, though.
Rocketman
Seabrook, Texas
« Reply #2 on: July 13, 2009, 09:12:07 AM »
I don't look forward to fumbling around with the seat lock, though.
The seat lock is a piece of cake.  Remove the left side seat cover, one or two bolts to loosen the center cover, and a clip to hold the lock cylinder.  Just pay attention to how the cable is put in there.  Not difficult, but it's hard to see in there sometimes.
« Reply #3 on: July 13, 2009, 10:06:32 AM »
Well, that's good news... I've never had the center cover off, or messed with anything behind, it, I figured it would be a drag...
I'm guessing the bag cylinders will not be hard to replace, anyone done that?
Rocketman
Seabrook, Texas
« Reply #4 on: July 13, 2009, 10:47:33 AM »
Don't bother taking it all the way off.  Just remove the bolts and work with it (mostly) in place.
When you replace the center cover, pay attention to the tab on the bottom.  It fits into a elongated oval grommet buried deep in there.  It's not obvious, but it obviously fits better when you seat that tab properly.
Can't help with the bag locks, but I don't imagine that's tough either.
Sharkey
GOT CURVES??
VRCCDS0184
« Reply #5 on: July 13, 2009, 02:30:39 PM »
How about the lock on the triple tree? Anyone change it out yet?
Sharkey
GOT CURVES??
VRCCDS0184
« Reply #6 on: July 14, 2009, 06:53:37 PM »
Well all the locks are replaced, except the tree lock. It is help in with two phillips screws that are not accessible with the forks on the bike. The seat lock was a little tricky, its tight in there. The set came with a new gas cap too, its on as well as the ignition switch.
"Bad Girlfriend" is officially ready for inzane. We leave in one week from today. WOO HOO
« Last Edit: July 14, 2009, 06:55:48 PM by Sharkey » Logged
Rocketman
Seabrook, Texas
« Reply #7 on: July 15, 2009, 12:29:09 PM »
In retrospect, I should have suggested that you take the petcock handle off to make it easier.  I don't have the stock, so I didn't think about it.  That probably would have made life easier.
Are you going to change the tree lock later, or just leave it?  I've never looked for those screws, but it doesn't surprise me.  If it was easy to remove, what would be the good?
Sharkey
GOT CURVES??
VRCCDS0184
« Reply #8 on: July 15, 2009, 03:10:52 PM »
I will probably get around to it eventually. I rarely use it.
I had the tank off already to change the ignition switch so the petcock extension was out of the way. I just got some big old hands, and had to get some help from Tinkerbell to get it done.
Mo Lee
Waynesville, Mo
« Reply #9 on: July 16, 2009, 01:52:36 AM »
Glad you got it done, I don't guess I was even aware the Valks had a fork lock. Guess that tells you how many times I've used it. Be safe on your trip we plan on being in Greeley next week visiting In-Laws Hope to take 1 day to come to Frisco. Still waiting on an answer if I need to preregister or can do it there. I guess if I have to preregister I will have to decide which day to come.
MP
North Dakota
« Reply #10 on: July 16, 2009, 09:40:39 AM »
You can do it there.  I did last year.  No problem.
MP
"Ridin' with Cycho"
Sharkey
GOT CURVES??
VRCCDS0184
« Reply #11 on: July 16, 2009, 06:18:47 PM »
Lee give me a shout when it gets closer and you know the day.
