November 25, 2025, 09:53:26 PM *
Author Topic: Front forks  (Read 1241 times)
ValkISDan
Forest Lake, MN
« on: September 15, 2013, 06:37:35 PM »
I've had my 2001 IS for so many years I'm not sure if this is normal or not. Just sitting on my bike causes my forks to drop a couple of inches and seems very soft. My bike only has 22K miles. Is this normal?
Denny47
#34898
Grove, Ok.
« Reply #1 on: September 15, 2013, 07:14:20 PM »
Yep. Springs get old and weak with time and use. Changed mine to Progressive for a Goldwing. Go to search box at center right of main page and enter   fork springs
USAF 66-70, F-105 AWCS
« Reply #2 on: September 17, 2013, 07:00:39 AM »
Sounds unusual for a bike with only 22K. Have you seen any signs of  fork oil is leaking?
My rides:
ValkISDan
Forest Lake, MN
« Reply #3 on: September 17, 2013, 04:33:18 PM »
No leaking just soft. I may just upgrade to progressive springs
Shelly
Nottingham, MD
« Reply #4 on: September 17, 2013, 05:09:57 PM »
I also have a 2001 Interstate with the same issue with my front shocks.  I have purchased the progressive springs for this model bike and I am getting ready to have them installed.  My question is - is it best to install them through the top of the forks which requires taking off the faring or pulling the lower legs apart and going that route which means replacing all the seals?  Any information on the best way to do this procedure would be appreciated.
Thanks.
olddog1946
Moses Lake, Wa
« Reply #5 on: September 17, 2013, 06:04:24 PM »
Thanks.
The springs can be changed out at the top. Do a search in the tech section and see how it's done. If you are going to have them installed and the installer is asking this question, GO SOMEWHERE ELSE.
VRCC # 32473
01 Valk Std.
02 BMW k1200LTE
sawdustar
Conway, AR
« Reply #6 on: September 17, 2013, 06:33:11 PM »
+1 on that.!!!
Thank You,
Dennis
