February 07, 2026, 08:22:58 PM *
Author Topic: "S" light??  (Read 1678 times)
Mud_Bug
Tyler, Tx
« on: September 19, 2013, 08:23:33 AM »
On the tach, the "S" light is illuminated on this 97. What is that light for and how do I turn it off...if possible??
Chippy01
Gorey, Ireland
« Reply #1 on: September 19, 2013, 08:31:44 AM »
It's to let you know that the side stand is still deployed. It should go out once the stand has been retracted. If it doesn't you could have a switch problem down at the stand.
'98 GL1500C Standard Valkyrie
'88 VF750C SuperMagna
'89 GL1500 GoldWing
vanagon40
Greenwood, IN
« Reply #2 on: September 19, 2013, 10:24:26 AM »
If you have a switch problem, I would expect the engine to die when you put the bike in gear.
Mud_Bug
Tyler, Tx
« Reply #3 on: September 19, 2013, 10:35:22 AM »
I put the kick stand up, sometimes the light goes out, other times it stays on. The bike does not ride or run irregular when the light stays on.
« Reply #4 on: September 19, 2013, 11:13:51 AM »
Put the bike in a wheel chock so it will stand up straight without any pressure on the sidestand. Then take a look underneath to see if the switch itself is loose. Removing the switch, if needed, is not too difficult, it's getting to the plug on the other end. It's in front of the battery box and you need 14" fingers and little hands to get to it. Bit of a PITA.
Valkpilot
What does the data say?
Corinth, Texas
« Reply #5 on: September 19, 2013, 12:34:43 PM »
Another point to check is that everything is tight in the boot full of connectors under the right side neck cover.  I had similar symptoms after riding all day in the rain.  The "S" light circuit was getting sneak voltage that the switch really knew nothing about.
VRCC #19757
IBA #44686
1998 Black Standard
2007 Goldwing
Mud_Bug
Tyler, Tx
« Reply #6 on: September 19, 2013, 06:45:01 PM »
Thanks guys. I'll check all of this out on my next day off.
garyheskett All 49 x 3 st.louis
St. Louis, Missouri
« Reply #7 on: September 30, 2013, 07:37:42 PM »
Be careful if you unplug the switch at the kickstand.  There are several metal "prongs" that will break very easily.  Or maybe mine did because the switch had been rotating some when the kickstand went up and down.
