February 07, 2026, 06:36:22 PM *
Author Topic: U joint advice.  (Read 1804 times)
« on: September 20, 2013, 06:06:38 AM »
I need info on u-joint  replacement.  I busted mine on a ride in the Ozarks this week.  Hoser  Shocked
« Reply #1 on: September 20, 2013, 06:26:40 AM »
OH, there's a lot of it. It may be in shop talk. Its definitely in the archives or search. Its not a hard job. The wheel and drive shaft have to come out/off, doesn't take too long.
« Reply #2 on: September 20, 2013, 06:44:00 AM »
Search is your friend, but here's the overview:  1. Buy new u-joint.  2. Remove busted u-joint.  3. Install new u-joint.
« Reply #3 on: September 20, 2013, 07:44:00 AM »
Sorry if your'e offended, I thought this was a tech conversation board.  Shocked Hoser
« Reply #4 on: September 20, 2013, 08:06:12 AM »
Hoser, the one post has it right....the rear wheel/drive shaft will have to come off. The link below shows how to remove the u-joint without removing the swingarm. It tells you to remove the exhaust but I've never had to. I will tell this....putting the rubber boot back on will sometimes make you forget everything you learned in church.  Wink  Some owners order a new boot at the same time they order the u-joint. The rubber is more flexible, hence easier to reinstall. Good luck.
http://www.rattlebars.com/mtz/ujoint.html
« Reply #5 on: September 20, 2013, 08:11:27 AM »
Maybe I'm wrong, but, I doubt anyone is offended. This is tech board and you got good advice. All the info is here, in the search function. We're all here for additional info or advice once the repair is started and if you have any questions. You'll have some, but, we don't know exactly what they will be. Everyone has different questions.
Daniel Meyer
The State of confusion.
« Reply #6 on: September 20, 2013, 08:38:49 AM »
Yep, good instructions at the link...no need to pull pipes/swingarm. Buy a new boot, definitely is easier to re-install, only costs like $8. Check/clean pinion cup while you're there.
CUAgain,
Daniel Meyer
« Reply #7 on: September 20, 2013, 09:57:24 AM »
I have a joint, I know how to remove the final drive and drive shaft. My main concern was the need to remove the swing arm.  Don't need to hear," Buy a u joint, remove the old one and install the new one".  The info in the link is what I need.  This is prime riding season around here, and I have places to go.  I guess it was me who was offended.  Sorry about that.  Hoser   Embarrassed
« Reply #8 on: September 20, 2013, 01:23:23 PM »
Nope, not offended.  I just think your request shows you haven't done any research for yourself and expect someone else to come up with the answer without even providing a question.  If the question is, "Do I need to remove the swing arm?" or, "Is there a write-up somewhere that thoroughly explains how to replace the u-joint?" then ask those questions.
art
Grants Pass,Or
Grants Pass,Or
« Reply #9 on: September 20, 2013, 03:28:50 PM »
THE BOOT! Big pain in the butt
GOOSE
D.S. #: 1643
Southwest Virginia
« Reply #10 on: September 20, 2013, 04:19:25 PM »
HOSER .... ONCE YOU TAKE THE WHEEL/FINAL DRIVE OUT REMOVE THE BOOT, AND LOWER THE SWING ARM DOWN .... WITH THE SWINGARM DOWN, YOU CAN REMOVE THE U-JOINT WITH NOT ALOT OF TROUBLE.  IT WILL BE EASIER IF YOU REMOVE, AND SET ASIDE THE REAR BRAKE MASTER CYLINDER.  WHILE IT IS ALL APART, JUST CHECK YOUR SWINGARM BEARINGS .... BY MOVING SWINGARM SIDE TO SIDE WITH LITTLE/NO PLAY, AND MAKING SURE IT MOVES UP, AND DOWN SMOOTHLY.  YOU WON'T HAVE ANY TROUBLE WITH IT.  GOOD LUCK.
« Reply #11 on: September 21, 2013, 07:47:15 AM »
Thanks everbody for the help.  Excuse my little red-ass episode .  Hoser   Wink
stude31
Topeka,ks
« Reply #12 on: September 21, 2013, 05:47:44 PM »
Your just down the road from me, get it up on your jack and I'll come over and help you out!  Oh yeah we already talked.  Maybe thursday of next week would work for me.  I'll need to check with momma and see if I am committed to anything for that day.  It is very nice outside you need to be on the bike so I'll do my best in getting there next week.
Stude31  cooldude
