February 07, 2026, 06:35:20 PM
new 2 me 98 standard
Topic: new 2 me 98 standard (Read 1118 times)
carl1up
sardinia ohio
September 20, 2013, 04:52:58 PM »
I got another valk red and cream great deal. po says it needs a alternator, I bought it. got home ,put a new battery in it and it wouldn't start looked here on the forum and found several things to check out. got to the fusible link and it was blown,changed it with the spare and wow she runs great. I pulled the neg cable off the battery and it stayed running at idle,should I still test alt? seems to run fine,will test a little more sat am riding my new 2 me second valk,love these fat girls thanks-------------carl
Re: new 2 me 98 standard
September 20, 2013, 05:18:24 PM »
Pulling the cable off the battery...not a good idea or method to check the alternator. Just put a voltmeter across the battery with the engine running and it should read in the 14+ volt range when you twist the throttle. No danger of burning something out that way.
pancho
Bonanza Arkansas
September 21, 2013, 03:06:28 PM »
What Stuffy said,, DO NOT pull a battery cable to check the alternator.,, just asking for damage to electrical and electronic components. That fuse blew for a reason,,, I would examine the alternator even if it is charging right now. How many miles on the bike?
carl1up
sardinia ohio
September 21, 2013, 03:37:45 PM »
tested at 14.2 at 2000 rpm this morning ,rode it about an hour seems to be all good. bike has 25000 miles on it its pretty clean. thanks all -----------------carl
