February 07, 2026, 06:35:20 PM *
Author Topic: Side stand "Special" bolt.......  (Read 1601 times)
Stanley Steamer
Athens, GA
« on: September 21, 2013, 08:00:27 AM »
is it part # 5 in this diagram??...and the nut..#7?......I think I mistakenly ordered part # 6 one time.......I do have the spring on hand.....with my '99 I/S getting on up there, I'm afraid that bolt is weak by now..... : Undecided
http://www.hdlparts.com/fiche_section_detail.asp?section=4223971&category=Motorcycles&make=Honda&year=1999&fveh=188145
Stanley "Steamer"
"Ride Hard or Stay Home"
« Reply #1 on: September 21, 2013, 08:10:08 AM »
You are correct.  Pretty good for a johnny reb.
Stanley Steamer
Athens, GA
« Reply #2 on: September 21, 2013, 08:17:24 AM »
 Cheesy Cheesy Cheesy.........I would have probably had to "cross" the line if I had of been around back then......
Stanley "Steamer"
« Reply #3 on: September 21, 2013, 08:34:12 AM »
That bolt will last longer than you'll be riding.
Especially if you lubricate it once in a while.
Stanley Steamer
Athens, GA
« Reply #4 on: September 21, 2013, 08:40:15 AM »
will KY work?........... Undecided Undecided Cheesy Cheesy cooldude cooldude Grin Grin
Stanley "Steamer"
Bone
« Reply #5 on: September 21, 2013, 08:46:18 AM »
My bolt was bent from the floor jack using it as a stop Sad
I did replace it before it broke.
Valkpilot
What does the data say?
Corinth, Texas
« Reply #6 on: September 21, 2013, 10:43:38 AM »
If you're looking for the bolt that the spring hooks to, it's #10 in this diagram:
http://www.hdlparts.com/fiche_section_detail.asp?section=2552469&category=Motorcycles&make=Honda&year=2000&fveh=132671
The bolt you referred to holds the kickstand in place and is its pivot.
« Last Edit: September 21, 2013, 10:45:46 AM by Valkpilot » Logged
VRCC #19757
IBA #44686
1998 Black Standard
2007 Goldwing
« Reply #7 on: September 21, 2013, 10:51:46 AM »
I think you meant #11
Stanley Steamer
Athens, GA
« Reply #8 on: September 21, 2013, 12:54:35 PM »
Well..........@%$@$#!!!!.....do I need part #30 also??....or does just the end break off when it breaks?...I think that is what I did last time......I wasn't even on the right microfiche....that's what I get for being too lazy to go LOOK at the bike and see where it was attached...... Angry Angry Angry............Thanks
« Last Edit: September 21, 2013, 12:56:31 PM by Stanley Steamer » Logged
Stanley "Steamer"
Stanley Steamer
Athens, GA
« Reply #9 on: September 21, 2013, 01:12:31 PM »
It's part #10 on the '99 I/S microfische.......I see on the 2000 CT models it was part #11
Stanley "Steamer"
Valkpilot
Corinth, Texas
« Reply #10 on: September 21, 2013, 01:55:29 PM »
Yep.
VRCC #19757
IBA #44686
1998 Black Standard
2007 Goldwing
