February 07, 2026, 08:22:56 PM *
Author Topic: Replacement Intake Manifold O-rings  (Read 4871 times)
2qmedic
Simply Awesome!!!
« on: September 22, 2013, 09:29:39 AM »
Gretings All,
I have tried (with out success) to find the information for replacement intake manifold O-rings. I am not talking about OEM, but a different type that is a much better quality O-ring. I replaced mine years ago and no fuel leak stains since, but I have a friend that needs his replaced also and looking for the information.
Does anyone have this info?
Thanks in advance
Charles
9Ball
« Reply #1 on: September 22, 2013, 09:41:09 AM »
http://www.ebay.com/itm/Intake-O-ring-Kit-for-Honda-Valkyrie-Viton-GF-/231027551196?pt=Motorcycles_Parts_Accessories&fits=Model%3AValkyrie&hash=item35ca50abdc&vxp=mtr
VRCC #6897, Joined May, 2000
1999 Standard
2007 Rocket 3
2005 VTX 1300S
AZdougness
« Reply #2 on: September 22, 2013, 10:10:26 AM »
http://redeye.ecrater.com/p/2064055/intake-o-ring-kit-viton-gf
If you want to skip ebay
IamGCW
727 hood
« Reply #3 on: September 22, 2013, 11:28:09 AM »
+1 cooldude
Gil
« Reply #4 on: September 22, 2013, 12:18:14 PM »
 cooldude cooldude
My rides:
2qmedic
Simply Awesome!!!
« Reply #5 on: September 22, 2013, 12:23:05 PM »
Cool beans !!!
Dat's it!!!
« Reply #6 on: September 22, 2013, 04:22:55 PM »
If mail order isn't fast enough, the size is a #123 and get Viton or silicone. A local hydraulic supply should have it.
2qmedic
Simply Awesome!!!
« Reply #7 on: September 22, 2013, 05:41:49 PM »
10-4
PhredValk
Edmonton, Alberta, Canada
« Reply #8 on: September 22, 2013, 06:55:22 PM »
Seeing that this is the best source for the 3 O rings needed for rear spline maintenance (they have a 15 o ring pack good for 5 rear changes) they also sell the intake O rings. I bought a set of each, good folks to deal with, good products.
http://www.carolinabikeandtrike.com/ORings.htm
Fred.
VRCCDS0237
~ Timbrwolf
Northern Michigan VRCC # 8533
« Reply #9 on: September 24, 2013, 07:46:25 AM »
...Im in need of these also and was worried about taking the entire carb assembly
off and then bolting it back on. Then I saw a guy on the FaceBook VRCC site,
that took the front and back intakes off and left the carb assembly on,
with only the middle intakes and I got the Idea to do this to replace the O Rings.
Anyone else done this, or know of a better way without removing the carbs ?  Cool
JC
The Beast
Franklin, TN
« Reply #10 on: September 24, 2013, 07:53:00 AM »
Just do one side at a time. Worked fine for me.
Also, while you're in the area, make sure all three hose clamps are tight on each intake (yes, there are 3 on each one).
9Ball
« Reply #11 on: September 24, 2013, 08:19:20 AM »
yes, just do one side at a time as mentioned above...easy stuff.
1999 Standard
2007 Rocket 3
2005 VTX 1300S
~ Timbrwolf
« Reply #12 on: September 25, 2013, 05:04:29 AM »
...Thanks John, I was hoping you,d chime in, Im gonna wait till the snow flies and do some
other work also. Hope you and Denise are doing well.  cooldude
9Ball
« Reply #13 on: September 25, 2013, 07:27:46 AM »
That job shouldn't take more than 20 minutes...just make sure not to over-tighten the intake bolts...they only need 6.5 lbf-ft.
1999 Standard
2007 Rocket 3
2005 VTX 1300S
Denny47
#34898
Grove, Ok.
« Reply #14 on: September 25, 2013, 07:14:08 PM »
Do all three on one side but don't tighten any of the bolts or clamps until  you have all three back in place and then tighten.
USAF 66-70, F-105 AWCS
Earl in Pensacola
« Reply #15 on: September 25, 2013, 08:05:11 PM »
You can do them ONE at a time!  Very easy & quick!
Rio Wil
« Reply #16 on: September 25, 2013, 10:11:00 PM »
Do one whole side at a time, loosen the runner nuts enough to raise all three runners up at once about 1/8 inch.  Use a dental pick to pull the o ring out.  Put a little grease for lube on the new o rings and slip them under the raised runners.  Position with the dental pick and lower the runners, the lube helps the o ring seat in the groove....
~ Timbrwolf
« Reply #17 on: September 28, 2013, 08:31:00 AM »
...Thank John...like I said earlier, its a winter project ..  cooldude
9Ball
« Reply #18 on: September 28, 2013, 08:32:31 AM »
that's only a few weeks away for you guys up north...
1999 Standard
2007 Rocket 3
2005 VTX 1300S
