January 29, 2026, 03:35:59 AM *
Author Topic: Rear Spline Replacement  (Read 2055 times)
Bladedog
Lompoc, CA (Central Coast)
« on: July 13, 2009, 04:38:08 PM »
Ok received the "new" rear end today.
Along with the three o-rings (ordered from Carolina Bike & Trike), what other items should I go ahead and replace while I'm in there?
I've read about the "thrust washer" and the "oil seal".  Can someone shed some light on exactly which parts these are?  And where to get them?
One final question, do I need PASTE or GREASE?  Or BOTH?  And what kind?  And where do I get it?  crazy2
It's easier to get forgiveness than permission.
Daniel Meyer
The State of confusion.
« Reply #1 on: July 13, 2009, 05:24:59 PM »
Thrust washer is a teflon washer that goes in between the wheel and the star...on that bearing surface. It keeps the star (as it flexes in the dampeners) from eating the wheel. Very important. Lots of folks lose them. Get it at honda.
Paste on the splines if you've got it...if you don't, the reality is any good quality waterproof grease will do. Assembly order is what is important (torque the axle before you tighten the 4 nuts that hold the pumpkin on. They are last.). Grease only in the pinion cup (not paste). It is lubed by the rear end oil and paste will clog it up. Make sure all the gunk is cleaned out of it before assembly.
CUAgain,
Daniel Meyer
« Reply #2 on: July 13, 2009, 05:43:58 PM »
What Daniel said... The manual says moly-grease ...  I see now, that's way
different from moly-paste...   uglystupid2
« Reply #3 on: July 13, 2009, 06:00:30 PM »
These folks are good to deal with and they've been friends to the VRCC.  http://guarddogmolylubricants.com/
Bladedog
« Reply #4 on: July 13, 2009, 09:15:18 PM »
Ok, good info.  What about the oil seal?  Or dust seal?  Are they the same thing?
