February 07, 2026, 06:30:22 PM *
Author Topic: Heavy Throttle  (Read 1296 times)
MotoMuffin
« on: September 23, 2013, 08:36:51 AM »
Hi Everybody:
I'm new to this forum and to Valkyrie ownership. I picked up a "barn find" 2000 standard that hadn't run in ~five years. I put a new battery in, new front tire, took the carburettors and fuel petcock apart, cleaned everything, and it's on the road now.
I have a question only other Valkyrie riders can answer, though. This bike has a very heavy throttle -- not just a little bit but a real wrist-murderer. Is that something these bikes are known for or does mine need more surgery?
Thanks for any advice you can offer,
Kate
2000 GL1500C Valkyrie
2001 BMW R1100S
2002 SV650
2008 KLR650
« Reply #1 on: September 23, 2013, 08:45:07 AM »
It shouldn't take more effort than on a typical motorcycle to twist the throttle, and it should snap back on its own with the bars turned left/centre/right.
MotoMuffin
« Reply #2 on: September 23, 2013, 08:47:09 AM »
Thanks for that. It's much heavier than anything I've ever ridden, so I'm guessing I need to double-check the routing and lube the cables. Thanks!
2001 BMW R1100S
2002 SV650
2008 KLR650
WamegoRob
Wamego, KS
« Reply #3 on: September 23, 2013, 08:53:13 AM »
Here's a quick write-up from one that recently did this:
http://www.valkyrieforum.com/bbs/index.php/topic,55130.msg529285.html#msg529285
MotoMuffin
« Reply #4 on: September 23, 2013, 09:00:07 AM »
That's exactly what I needed, thank you very much!!
2001 BMW R1100S
2002 SV650
2008 KLR650
Pappy!
Central Florida - Eustis
« Reply #5 on: September 23, 2013, 04:43:59 PM »
By the way - Welcome aboard!
Always nice to see a gal riding a Valkyrie ! Wish I could get my g'friend to climb on mine and ride it. She already rides the Magna and has a Vstar 1100. Would consider a second Valk if she would.
olddog1946
Moses Lake, Wa
« Reply #6 on: September 23, 2013, 10:18:37 PM »
Welcome aboard..it's your turn to buy the donuts, hehe.
If you don't have the stock risers on your bike, you might find a previous owner may have re-routed the cables behind the forks to effectively increase the reach of them, unfortunately that causes a pretty sever bend at the front of the tank. This bend increases the wear on the inner sleeve and will lead to binding. If that's been done you only choice is to replace the cables, preferably with longer ones.
VRCC # 32473
01 Valk Std.
02 BMW k1200LTE
« Reply #7 on: September 24, 2013, 06:08:08 AM »
Welcome to the asylum Motomuffin!  Smiley You are going to love your Valk. If the throttle felt good before the carbs were cleaned up, you probably do have a routing problem. It's a tight fit where they connect.
My rides:
