February 07, 2026, 06:36:23 PM *
Author Topic: used brake fluid  (Read 1329 times)
alph
Eau Claire, WI.
« on: September 25, 2013, 05:27:12 PM »
alright, what do you do with old brake fluid?  when I change my engine oil I collect it in a 5 gallon jug, bring it down to the jiffy lube place were they burn it for heating their building,
but, what do you do with old brown, brake/clutch fluid?
Six-Cylinder Hooligan
« Reply #1 on: September 25, 2013, 05:52:57 PM »
I dump that shite in the same 5-gallon jug that I put my used oil in.  cooldude
« Reply #2 on: September 25, 2013, 07:06:30 PM »
I just read somewhere (here?) that brake fluid is glycol.
Treat it the same as your old anti freeze then.
matt
Derry New Hampshire
« Reply #3 on: September 26, 2013, 08:29:50 AM »
at the shop we put engine oil,brake fluid and transmission fluid all in same waste container
JC
The Beast
Franklin, TN
« Reply #4 on: September 27, 2013, 06:58:44 AM »
I dump mine in with my old oil too.
Brake fluid is nothing more than a hydraulic fluid/oil and it is accepted practice in most areas for it to be dumped in the same recycle tank.
They send it to a secondary refinery where it is processed and split into fractions, then sent to other refiners/blenders to be either returned to the production cycle, or if it's too heavy it'll go to a cement kiln for burner fuel.
Gary
Northern New Mexico
« Reply #5 on: September 27, 2013, 09:19:26 AM »
Here, the ecology station (local dump) took mine in the same pickle jar it was collected in as long as it was clearly marked. I had marked the lid with "used brake fluid". No fee charged after they confirmed I was a local.
