January 29, 2026, 03:36:45 AM
Question about Progressive shock length
Topic: Question about Progressive shock length (Read 2126 times)
Old Geezer Richard
San Antonio , Tx
July 15, 2009, 09:48:53 AM »
I am also thinking about upgrading to the HD prog. shock .... is there any advantage or disadvantage to using the 13 1/2 inch shock versus using the 13 inch ....I am 6 ft. at 250 , ride alot solo but I do ride two up .... would it make for a bumpy or stiff ride ? ...... Thanks Old Geezer
If you don't care where you're going, then you ain't lost , Murphy's Law because wherever you are going to , it ain't going nowhere .... San Antonio,Tx.
Mr.BubblesVRCCDS0008
Re: Question about Progressive shock length
July 15, 2009, 10:47:12 AM »
12.5 in progressive is stock replacement for valk. Progressive has less sag. I run 13 in progressives on my I/S and it raised the rear up about an in. I'm 6'3" and I like the extra height but it makes the bike lean hard on the kickstand. I runs the HD springs and Richard I've ridden with you at the mid winter ride I'ld think you'ld want the HDs.
Udo
Germany, Krefeld
July 15, 2009, 12:29:09 PM »
I´m also 6'3" and 260 (don´t tell my wife, pls, i don´t like to go to bed hungry). I have the Progr 440 HD in 12". I ride only 1 up, and like them a lot. I have them on the lowest setting.
