February 07, 2026, 08:22:57 PM *
Author Topic: Exhaust rattles  (Read 1281 times)
Pepmyster
Go Bonzo, Go!!!!
Mascouche, Quebec, Canada
« on: October 14, 2013, 08:17:57 AM »
Hi guys! I got 50% of all exhaust rattles covered. A lot better than it was. Now, when I am going up a hill and force the engine, it is like a engine growl. I have seen on the board the famous long bolt which has to be tightened, did that. If anyone has anything else I should check, please let me know.
Thanks in advance.
Now this is getting interesting........
« Reply #1 on: October 14, 2013, 02:57:25 PM »
The most common exhaust rattle is not the exhaust at all, it is the heat shields under the bags and over the rear pipes.  They are just thin metal, and often rattle against the top of the rear pipes.  To prevent them from laying on my airflow truck stacks and rusting the stacks, I bend mine up a wee bit, then have to push the bags down on them to get them bolted up.  All tight, no rattles, and no more rust.
Pull your bags and tap the shields to see if they are rattling, or rusting a thin line on your exhaust tips.
Pepmyster
Go Bonzo, Go!!!!
« Reply #2 on: October 14, 2013, 03:08:20 PM »
Thanks for the reply, Those have been taken care of already. It sounds like it is coming from the front of the bike........
Denny47
#34898
Grove, Ok.
« Reply #3 on: October 14, 2013, 04:16:45 PM »
I have a National Cycle all-metal front fender tip that bolts on. Started hearing a rattle up front and upon checking, I found that the two nuts on the small bolts had loosened up. Tightened and rattle was gone.
USAF 66-70, F-105 AWCS
Pepmyster
Go Bonzo, Go!!!!
« Reply #4 on: October 15, 2013, 02:45:12 AM »
I'll take a look at mine today.......
3W-lonerider
Shippensburg Pa
« Reply #5 on: October 19, 2013, 04:11:39 PM »
try this..it might be what your looking for
http://www.valkyrieforum.com/bbs/index.php/topic,57770.0.html
Pepmyster
Go Bonzo, Go!!!!
« Reply #6 on: October 22, 2013, 09:30:47 AM »
A personal thank you to all who have put in their input. This morning, after I have done the alt bracket modification, I went for a ride to go to work. WOW!!! What a difference!!!!!!! Thank you, thank you , thank you!!!!!!!! You guys are a great bunch!!!!!!!! cooldude cooldude cooldude
3W-lonerider
Shippensburg Pa
« Reply #7 on: October 22, 2013, 03:05:58 PM »
SWEET.. cooldude
