March 10, 2026, 04:55:06 PM
exhaust temp question...
Topic: exhaust temp question... (Read 1391 times)
deacon
NW Ohio
July 16, 2009, 09:57:35 AM »
I'm still getting used to this engine vs. my v-twin, so this might be a simple question. I've got MarkT's exhaust with 4" stacks. I've been running with glass packs for the last couple months (when I bought the Valk). I didn't notice anything before, but just yesterday I saw just a slight bit of blueing at the very tip of the exhaust on one side. Just a tiny bit right around the rim of the stack. The rest of the exhaust looks great. Am I running too hot? Is there anything specific/simple I need to check before becoming too concerned? It's really not noticable, but if there could be a problem, I want to catch it right away. Thanks in advance for any suggestions...
Dan
98 Valkyrie Standard, converted to tourer with a bunch of other goodies...
BamaJack
McCalla, Alabama
Re: exhaust temp question...
July 16, 2009, 11:39:05 AM »
You might want to ask that on the Tech board as well... The wrenches hang out there
I've been running Mark-T's for about 2.5 years now and I've not had a problem... are you sure it's bluing and not exhaust residue?
Jack in Bama - vrcc#10322 Phyllis (PeeK) in Bama - vrcc#19668
2000 I/S Super Valk 2000 Tourer
1999 Interstate 2003 Standard
DeathWishBikerDude
July 16, 2009, 11:49:02 AM »
Most likely causes for blueing pipes is a lean exhaust mixture.
Usually happens when changing pipes and not rejetting the carbs.
Master Blaster
Deridder, Louisiana
July 16, 2009, 05:33:43 PM »
Actually no need to rejet for any of the glasspack conversions. As long as you use the stock headers there is no problem. You can blue the headers even though they are double walled by idling too long with the choke on. Its unlikely that your exhaust will generate enough heat to blue the truck stacks.
