January 29, 2026, 03:58:38 AM *
Author Topic: Dis-connecting the battery  (Read 1930 times)
Andy
« on: July 17, 2009, 09:02:37 PM »
When dis-connecting the battery is it negative wire first or positive or does it even matter.
Sharkey
GOT CURVES??
VRCCDS0184
« Reply #1 on: July 17, 2009, 09:11:10 PM »
I always do the negative first. That way if you slip with a wrench you will not complete the circuit between the postive and the frame. When re connecting you do the negative last.
« Reply #2 on: July 17, 2009, 10:42:58 PM »
I always do the negative first. That way if you slip with a wrench you will not complete the circuit between the positive and the frame. When re connecting you do the negative last.
This was the procedure we were taught in Auto/Diesel class in school.
Andy
« Reply #3 on: July 18, 2009, 04:58:21 AM »
Thanks guys cooldude
Farther
Quimper Peninsula, WA
« Reply #4 on: July 18, 2009, 08:04:38 AM »
Owner's manual says neg first.  A new battery install is first on my list this morning.
~Farther
