February 07, 2026, 11:41:17 PM *
Author Topic: Interstate gas tank on a standard?  (Read 6549 times)
BigChris99
Hesperia CA
« on: November 17, 2013, 01:19:15 AM »
I'm seriously thinking about trying to track down an Interstate tank for my '97 standard. If I find one, is it a straight forward switch? I have all my badges and of course my gas cap. Anything else I would need? I know I might not find a black tank, so I would need to get it painted. How much bigger is the Interstate tank than a standard tank? Last, I have looked on our classifieds but I haven't seen one for sale, anyone have an Interstate tank they want to sell me?  Smiley
In 5th gear.... looking for 6th
VRCC # 35023   IBA # 7849
ricoman
Sarasota, FL
« Reply #1 on: November 17, 2013, 04:01:50 AM »
I t will bolt right on in same mounting holes you use now.
You may have a small issue with the nose of your seat needing to be bent up at the front to fit behind the tank. The I/S tank is taller at the rear (that's why it holds more gas) and the fit of your seat will be snug to it.
You will need to block off the hole for  the fuel guage sending unit or get an aftermarket guage. Do a search here-there is a lot of info on this subject.
Dust off your wallet, it won't be cheap.
MP
North Dakota
« Reply #2 on: November 17, 2013, 05:02:06 AM »
1.6 gal bigger?
I put one on my std.  BEST mod I have done.
MP
"Ridin' with Cycho"
« Reply #3 on: November 17, 2013, 05:29:24 AM »
A little info:
http://www.timskelton.com/valkyrie/how_to/tank.htm
« Reply #4 on: November 17, 2013, 05:53:34 AM »
BigBF sells a sending unit blockoff kit for a missing sending unit for the fuel gauge. The seat will need a nose job. Some of the foam in the seat can be shaved and recovered. If you get a sending unit, Motosens sells a fuel gauge that's a direct wireup and works well.
Farther
Quimper Peninsula, WA
« Reply #5 on: November 17, 2013, 09:01:17 AM »
Good luck finding an acceptable tank.  If your Interstate tank search fails and you want increased capacity then check out the R&M Works belly tank. http://www.rmworksinc.com/
~Farther
BigChris99
Hesperia CA
« Reply #6 on: November 17, 2013, 12:00:48 PM »
Thanks for all the info. I may contact R&M about a belly tank. I had forgotten all about that option. Thank you for the link. 3 extra gallons of gas would be wonderful, especially sitting so low.
1500Rider
« Reply #7 on: November 17, 2013, 01:51:26 PM »
Added an Interstate tank to my '97 Tourer without any modifications. Stock seat also fits without any mods to the seat itself. The only thing I did was put a small cut out of that clear, plastic shield they use to prevent rock chips on cars at the back of the tank where the seat touches. This keeps the seat from rubbing on the tank. As I had the new tank custom painted, I didn't want to mark up the paint.
I was told by many the fit of the seat would be quite tight. It wasn't.
Instead of buying the kit to block off the hole for the sending unit, consider buying the sending unit itself. This will allow you to add a fuel gauge down the road should you decided to go that route. Even if you don't, you can always put one in at a later date.
You'll love the extra fuel capacity too. One of those mods where, at least to me, there is no downside.
1990 Honda VFR750F
1997 Honda Valkyrie GL1500 Tourer
1998 Honda Gold Wing GL1500 SE
mike4sho
Salinas, CA
« Reply #8 on: November 17, 2013, 09:55:17 PM »
I have a belly tank on my standard.  Formano did the instal.  Best money spent.  My range is jow about 240 miles and you don't notice the belly tank.  Helps with the center gravity and no more worriss about the hydrolock.  I say that over the tank unless you want a bigger range, then get both.
1997 Valkyrie<br />2003 VTX 1800c<br />2004 Valkyrie Rune<br />2009 Shadow Aero 750
Glenn-B
Holmfirth - West Yorkshire - UK
« Reply #9 on: November 19, 2013, 11:57:38 AM »
Yup the R&M belly tank is superb coolsmiley I wont bore you with details, but I've modded my installation so that it runs on gravity feed until she hits reserve then I just flick a switch to activate the belly tank fuel pump. This way I have an idea how much fuel I'm using, and also the pump isn't working full time cooldude
The most mileage I've done with mine between fill ups [she's a 98 standard] is 285 miles with a litre to spare Wink
97BLKVALK
VRCC#26021
Detroit Lakes, MN
« Reply #10 on: November 19, 2013, 06:46:42 PM »
1.6 gal bigger?
MP
 cooldude  Totally agree with MP
Michael
1997 GL1500C - Black
1997 GL1500C - Purple
1997 GL1500C - Bumble Bee
1998 GL1500C - Blue and Cream
michaelyoung254
Huntsville, Texas
« Reply #11 on: November 19, 2013, 07:06:30 PM »
There's one for sale on eBay right now. Comes with petcock and fuel sending unit.
http://www.ebay.com/itm/97-03-Valkyrie-Interstate-GL1500CF-Gas-Fuel-Petrol-Tank-Cell-W-Petcock-Cap-/200990065051?pt=Motorcycles_Parts_Accessories&vxp=mtr&hash=item2ecbf1019b#viTabs_0
BTW, I put one on my standard, and I'm loving it. I wouldn't hesitate to do it all over again.
1998 Standard - Pearl Sedona Red & Ivory Cream
BigChris99
Hesperia CA
« Reply #12 on: November 22, 2013, 04:14:43 AM »
That E-bay tank is nice.... cooldude It's almost too pretty to think about it painted black. I think I'll watch it and see where the price goes. Thanks for the link.
maniscar
VRCC #2225
Southern NH
« Reply #13 on: November 22, 2013, 05:09:29 AM »
Can't use the belly tank on my bike because I have the Rivco center stand.  But I do have a '01 IS tank with fuel sender and fuel gauge on my '03 Standard.  Enjoying the extra miles between fill ups!
2003 Valkyrie Standard
