RonHolly
USAF Ret. '68-'92
Tampa, Florida
« on: November 18, 2013, 06:17:29 AM » |
Any cruiser should have a cruise control. [In my opinion!] Who got em and who's wanting to show them? Is Audiovox CCS-100 the one to own or some orther? Share some pics and your opinions. Thanks
Oh, as a side note! How do I make my postings in real time instead of another time zone?
« Last Edit: November 18, 2013, 06:20:00 AM by RonHolly »
'98 Valkyrie, '05 Triumph Speedmaster '77 Gold Wing, '81 Gold Wing,
Grumpy
« Reply #1 on: November 18, 2013, 06:53:03 AM » |
I have the Audiovox on my Interstate, love it. Real nice on long trips, holds the set speed with in a couple mph, even in the mountains.
« Reply #2 on: November 18, 2013, 07:00:20 AM » |
I've had the Audiovox system on my Tourer for most of the time I've had the bike(going on 11 yrs.). I made a couple changes at the beginning on the wiring installation and have never had a problem. At the time, Autozone had a supply they were trying to unload due to lack of sales, so I spent less than $30 on mine. There are other systems out there but the cost is much, much higher....but are totally electronic rather than vacuum operated like the Audivox.
As for second question....generally won't happen. You'll find that on just about any public forum, the posting is time stamped according to the server location. Not always, but usually it is. Your post is time stamped at 06:17 which is most likely California time, and I'll bet it was 09:17 here in Florida when you posted it.
« Reply #3 on: November 18, 2013, 07:05:42 AM » |
There's a member whose handle is TERMITE and whose profile has good email addresses...
He is some kind of contact for the same kind of cruise control that Frank Smoak used to rave about... made in Australia I think...
RonHolly
USAF Ret. '68-'92
Tampa, Florida
« Reply #4 on: November 18, 2013, 07:15:23 AM » |
I have an Audiovox in my '95 Ford truck that only gets driven once or twice a year to haul trash. I'm thinking of removing it and using it on my new Valkyrie. All I'd have to do is make a vaccum tank out of PVC pipe and do some improvising for the brake hydralic and throttle linkage. Think I just might do that.
98pacecar
« Reply #5 on: November 18, 2013, 08:33:19 AM » |
I have a question about board settings, as well? At the present I am unable to post a ''reply'' or start a ''new topic'' as both of these buttons are nowhere,, to be found, on the page. Weird because they were, there,,,, for several days, and I did,,, start a few threads a while back. Now, the only way I can post is to click on the ''quote'' inside a previous post, erase the message, n' type in mine. Sorry if I'm hijacking this thread,,,  but it's the only way I can post,,, at all. I'm no computer wiz but have tried turning off all the safety crap on my puter n' still no luck.. Anyone ever had this problem, or have a suggestion on solving it? Jim
RonHolly
USAF Ret. '68-'92
Tampa, Florida
« Reply #6 on: November 18, 2013, 08:43:46 AM » |
Almost sounds like you are not signed in and won't let you do much. Try signing in and see what happens. Good luck! Ron
98pacecar
« Reply #7 on: November 18, 2013, 08:47:38 AM » |
Yes you can adjust it Click on your '' name'' at the top left, of a post under ''modify profile'' click, on'' look n' layout''. see, ''time offset'' and set it at 3 hrs. at bottom of page click, ''change profile''... Yer done.
« Last Edit: November 18, 2013, 08:54:17 AM by 98pacecar »
« Reply #8 on: November 18, 2013, 08:48:19 AM » |
My guess is you'll find Reply if you scroll all the way to the last post in a thread and look down there in the list of buttons at the bottom right... I make new threads by hitting home->general and then I can see a "new post" button... -Mike
98pacecar
« Reply #9 on: November 18, 2013, 08:53:04 AM » |
My guess is you'll find Reply if you scroll all the way to the last post in a thread and look down there in the list of buttons at the bottom right... I make new threads by hitting home->general and then I can see a "new post" button... -Mike Just tried both, n' neither button,,, was there.  N' I a,,,,m signed in, because the ''log out'' button is there.
« Last Edit: November 18, 2013, 08:55:52 AM by 98pacecar »
« Reply #10 on: November 18, 2013, 08:57:48 AM » |
I was going from memory, I didn't realize there was actually a button there called "general"... try this for new posts...
home->"general board"
... replace "general board" with whatever board that's there that you want to post on...
I don't know what to say about the reply button... ?
98pacecar
« Reply #11 on: November 18, 2013, 09:04:33 AM » |
Shouldn't it be in the upper right,,, of this screen capture,,,,, if not where? http://i3.photobucket.com/albums/y82/zturb0/Capture_zps26eede56.png
98pacecar
« Reply #12 on: November 18, 2013, 09:13:21 AM » |
« Reply #13 on: November 18, 2013, 09:31:33 AM » |
Your "theme" seems very different from the one I use (I use "core")...
You can see what theme you have in profile->look-and-feel ...
I bet a moderator could get you fixed up in a jiffy if you ask...
« Reply #14 on: November 18, 2013, 09:38:02 AM » |
Yes it IS made in Australia. I put it on MGM during the winter of 1997/1998. I has over 243K miles on it and as of this writing, Nary a problem with it. I can set it on a long trip and it will run +2 to - 2 MPH. It is all electronic, no vacuum can. Yes, it is expensive, but for the value it has given me, it was well worth the time, trouble and $$$ to install it. The installtion instructions are very detail in nature, so no screw ups were done on my installation. Did I say I loved this unit? Well worth the $$$ for it, and yes I just love it to death.
« Reply #15 on: November 18, 2013, 09:41:07 AM » |
Ya beat me to it Ron, yupper, ya no signed in. Hope ya haven't forgot you handle and password.
98pacecar
« Reply #16 on: November 18, 2013, 09:44:17 AM » |
Ya beat me to it Ron, yupper, ya no signed in. Hope ya haven't forgot you handle and password. I AM,,,,,,,,,,,,,,,,,, SIGNED IN..... The ''log out'' button IS THERE. I've signed in,,,, n' out,,,,,,, several times,,, no change..  Look,,,,,,,,, in the first screen capture,,, see the ''log out''???
Bert AKA,Valkaholic
« Reply #17 on: November 18, 2013, 12:40:05 PM » |
Ya beat me to it Ron, yupper, ya no signed in. Hope ya haven't forgot you handle and password. I AM,,,,,,,,,,,,,,,,,, SIGNED IN..... The ''log out'' button IS THERE. I've signed in,,,, n' out,,,,,,, several times,,, no change..  Look,,,,,,,,, in the first screen capture,,, see the ''log out''??? In order to Start a new Post you have to be where all of the Threads are Posted and at the Top Left is a NEW TOPIC Button. You can 't start a New Topic While Reading Someone's Post and to Reply To a Post there is a REPLY Button at the Left Side of the Page at the Bottom of the Last Reply on the Subject Thread. Hope This Helps, Bert.
98pacecar
« Reply #18 on: November 18, 2013, 01:07:30 PM » |
Ya beat me to it Ron, yupper, ya no signed in. Hope ya haven't forgot you handle and password. I AM,,,,,,,,,,,,,,,,,, SIGNED IN..... The ''log out'' button IS THERE. I've signed in,,,, n' out,,,,,,, several times,,, no change..  Look,,,,,,,,, in the first screen capture,,, see the ''log out''??? In order to Start a new Post you have to be where all of the Threads are Posted and at the Top Left is a NEW TOPIC Button. You can 't start a New Topic While Reading Someone's Post and to Reply To a Post there is a REPLY Button at the Left Side of the Page at the Bottom of the Last Reply on the Subject Thread. Hope This Helps, Bert. That's THE PROBLEM,,, Look in the screen capture below the ''new topic'' button IS NOT THERE.... http://i3.photobucket.com/albums/y82/zturb0/Capture222_zps0cd14f3f.png
RonHolly
USAF Ret. '68-'92
Tampa, Florida
« Reply #19 on: November 18, 2013, 02:15:57 PM » |
Just emailed you a contact phone number for the Michigan VRCC. Searched all over the web trying to find any phone contact and found this one. (313-768-5014 select #2 if recording) Maybe they can help if it's a good number. Funny how the Main VRCC doesn't have any personal contact info! (None that I could find.)
Grumpy
« Reply #20 on: November 18, 2013, 04:53:03 PM » |
To contact staff use this link on the lower part of this page. http://www.vrccservices.com/contact/contact.phpThat will get you in contact with the staff, they should be able to correct the problem.
98pacecar
« Reply #21 on: November 19, 2013, 05:34:40 AM » |
Ok email sent,,,,,,,,, thanks..
98pacecar
« Reply #22 on: November 19, 2013, 05:35:56 AM » |
Thanks, I will try the number if the email fails,,,, to get a reply. Jim
98pacecar
« Reply #23 on: November 19, 2013, 12:19:58 PM » |
Scott SOLVED,,,, the problem for me.  Working like a champ now.. Muchas Gracias Scott.
« Reply #24 on: November 19, 2013, 12:59:06 PM » |
What was the problem? I am curious now..... Hay  Jimmyt
98pacecar
« Reply #25 on: November 19, 2013, 01:31:03 PM » |
What was the problem? I am curious now..... Hay  Jimmyt The ''new topic'' or ''reply'' buttons (and several others I guess) were no where on the page. So the only way I could reply was click Quote, erase the text, then fill in my reply. No way, could I start a new thread,,,,,, at all. Switching themes,,, solved it....
« Reply #26 on: November 19, 2013, 02:46:47 PM » |
AHA!!! Themes..... I just use the default, so I couldn't repeat your problem. Sometimes the page takes a while to load and the bottom of the page loads last. I have seen that pretty often, but I don't think it is the site, but our connection here at work. I like to click on the "Jump To" menu at the bottom right of posts to move to other parts of the site quickly and when the page loads slowly, that menu option doesn't show for a few seconds and I have to reload the page at times. BUT, it's all good. Rode the Valk to work today. Life is good. Hay  Jimmyt
