November 25, 2025, 10:25:28 PM *
Author Topic: Is there an easy way,,,  (Read 1341 times)
98pacecar
« on: December 09, 2013, 10:47:55 AM »
To tell if your valk has been desmogged??  coolsmiley
Or, do you need to pull the tank,, or something else, ta get to the area where alla da smog crap usta be??  Undecided
« Reply #1 on: December 09, 2013, 10:53:58 AM »
Yes.
Look at the top of the engine. Is the pair valve in place ? Then it hasn't been. If the top of the engine is clean/bare then it has been.
Look on the back side of the intake runners. If all [ except #6] are capped, then it has been. If #3 and #4 have vacuum lines heading towards the center of the engine, then it has not.
If the exhaust tubes from #s 1,5,2,6 on top of the engine are removed or capped off then it has been. As well as #s 3,4 on bottom of engine.
Farther
Quimper Peninsula, WA
« Reply #2 on: December 09, 2013, 11:14:37 AM »
There is a stealth desmog kit out there that might make the diagnosis more of a challenge.
~Farther
98pacecar
« Reply #3 on: December 09, 2013, 12:04:48 PM »
N' dat is???????????  coolsmiley
98pacecar
« Reply #4 on: December 09, 2013, 12:09:44 PM »
Yes.
Far as I can tell,, mine looks stock..  Cheesy
Mine might also be, a Calif bike ??   Undecided
Read in da vin # section,,, dat of my year, n' color,, the first group produced were,, for Calif.. mine is # 192..
Have no idea,, how many calif,, bikes they produced....    Sad
« Reply #5 on: December 09, 2013, 12:12:01 PM »
for a calif bike, look for the charcoal canister under the swing arm.
see shop talk for pics of desmog.
98pacecar
« Reply #6 on: December 09, 2013, 12:12:59 PM »
As yer sittin ON,,,,,,,,,,, da bike, lookin down,,, how are the cylinders numbered??   Shocked
1 front left, 2 front right n' so toward da back,, errr what?   coolsmiley
98pacecar
« Reply #7 on: December 09, 2013, 12:18:33 PM »
No ''canister'',,  So that's a plus..
Whilst down there,, I pulled a plug out of a clear plastic drain line n' got bout a teaspoon of water out.
What,,,, is this drain,,, connected too?   Undecided
« Reply #8 on: December 09, 2013, 12:26:11 PM »
That line is connected to the bottom of the airfilter box. Doesn't sound like you had much "dragon drool".  2funny
« Last Edit: December 09, 2013, 12:28:50 PM by salty1 » Logged
My rides:
Farther
« Reply #9 on: December 09, 2013, 12:27:40 PM »
N' dat is?
http://redeye.ecrater.com/p/4871422/stealth-desmog-kit-honda-valkyrie
~Farther
« Reply #10 on: December 09, 2013, 12:30:41 PM »
That line is a drain for the 'dragon drool'.
As you sit on the bike; #1 is right front, #5 right rear; #2 is left front, #6 left rear[petcock line].
« Reply #11 on: December 09, 2013, 12:32:16 PM »
My first desmog was with a redeye stealth kit and there was no way of telling ithe bike was modified. Later removed the whole pair system so I would have plenty of room to install a Dan Marc fuel shut off.
My rides:
98pacecar
« Reply #12 on: December 09, 2013, 01:13:08 PM »
Certainly, cheap,,,,,,,,,,,,, enuff....     coolsmiley
« Reply #13 on: December 09, 2013, 01:56:39 PM »
If you look thru shop talk, you'll find the best article ever written on desmog by our long time member Normand [Quexpress].
98pacecar
« Reply #14 on: December 09, 2013, 02:05:36 PM »
Just,,,,,,,,,,, came from, there...   Wink
Looks like a wealth,,,, of solid info...    cooldude
Read most,,, of the desmog link.
Haven't decided yet wither to screw with it errrr not.  Cheesy
I'm a commercial refrigeration mech (retired) by trade.
Learned long time ago, if it works,,, it's prolly best not,,,, to mess with it.
My bike runs great, as it sits..  Sooooooooooooooo...  Cool
« Reply #15 on: December 09, 2013, 02:12:14 PM »
Reminds me of the old saying. If it ain't broke keep fixing it until it is.
« Reply #16 on: December 09, 2013, 02:24:32 PM »
The deal with desmog..... it does not make the bike run better or more efficiently (so long as it's all in perfect shape), but all that vacuum hose eventually degrades and causes a degradation in engine performance, slowly (maybe unoticeably) over time, maybe some exhaust popping, maybe a failure in the OE petcock vacuum.  So about the time you start finding rotted/hard vacuum lines, rather than replacing it all, it's better to just remove it all.  Then it will never be a problem again.  The issue with OE smog parts is not miles, but age and environmental exposure.
This kit is spendy but I think the best for those of us who don't do well cobbling together stuff from auto parts and JB weld and rubber caps. Used one on each bike, along with a OE petcock rebuilds, valves reset, and carb synch, plugs and air filters.  Both bikes ran fine before all this, and both were like new afterwards. (80K and 60K)
http://xf6-custom.com/partpages/desmog.html
Drain the drool tube every few months, and at oil changes.  And after any long distance rain riding.
« Reply #17 on: December 09, 2013, 02:41:56 PM »
I used Daryl's kit.  I like the fit of the blocking plates for the bottom of the heads.  The stainless plugs fit like a glove too...
My $.01875
Hay  Cool
BradValk48237
Oak Park, MI
« Reply #18 on: December 10, 2013, 06:59:15 AM »
One easy way to tell if it has had a full desmog is to look between the carbs....
If you can easily see through to the other side, them a lot of the Smog parts have been removed.... if its dark and full of stuff, then probably not.
Brad
Brian
Monroe, NC
« Reply #19 on: December 13, 2013, 03:13:56 AM »
The cheap route I took the first time was to remove the smog valves, plug the vacuum port and the airbox connection. I then used JB Weld in the ends of the six exhaust tubes. Just this spring I tried doing the 14mm or 9/16's freeze plug in one port. I plan to really finish the project right this winter.
