February 08, 2026, 01:13:57 AM *
Author Topic: clutch handle question  (Read 1263 times)
vw70blue
Tampa, FL
« on: December 18, 2013, 03:59:50 PM »
After the clutch handle is removed, can you pull out the push rod and boot? And will fluid come out? Thanks
Highbinder
Bastian/Tazewell,VA.
« Reply #1 on: December 18, 2013, 05:20:41 PM »
I've pulled them out serveral times and never had fluid come out..the dust cover is just to keep dirt out.
RudyF6
Chelsea, Michigan
« Reply #2 on: December 23, 2013, 01:29:19 PM »
Pull it out, clean it and put a dab of grease on the ends - makes for buttery smooth clutch lever action!  cooldude
You can never be lost if you don't care where you're going!
98 "Tourerstate" (Std. with I/S bags/trunk)
98 Tourer solo ride
81 CBX
BobB
« Reply #3 on: December 23, 2013, 01:55:38 PM »
The simple answer is yes.  The hydraulic fluid is sealed in with seals on a piston which is retained body by a small snap ring.  I currently have my master cylinders completely apart and will be rebuilding them in the near future.
vw70blue
Tampa, FL
« Reply #4 on: December 30, 2013, 06:03:29 PM »
So if there is fluid behind the boot, will I need to change the piston assembly?
Michvalk
Remus, Mi
« Reply #5 on: December 30, 2013, 06:19:51 PM »
The short answer is yes. There shouldn't be any fluid in there. cooldude
atxvalk
« Reply #6 on: December 30, 2013, 09:49:20 PM »
I just replaced my handle, bushing, push rod and boot. The boot and push rod will pull right out without exposing the master cyclindr or fluid. The new rod and boot can be reinstalled witout any fluid loss.
vw70blue
Tampa, FL
« Reply #7 on: January 01, 2014, 12:59:41 PM »
