November 25, 2025, 10:30:11 PM *
Author Topic: Rear turn signals and brake light  (Read 962 times)
bearzdiehard
« on: December 28, 2013, 01:30:08 PM »
HELP. my 1998 standard suddenly started having issues with the turn signals.  When the front right signal is on the rear left signal as well as the brake light flashes and vice versa. I have checked the wiring and it is all the way it should be. Could there be some kind of relay involved?
« Reply #1 on: December 28, 2013, 01:45:39 PM »
Did you just have the rear fender section off ? It sounds like a rear connector problem.
« Reply #2 on: December 28, 2013, 04:27:56 PM »
Bad grounds can cause strange turn signal issues. Check bulbs, clean all plugs and check battery grounds.
Michvalk
Remus, Mi
« Reply #3 on: December 28, 2013, 04:34:41 PM »
There is a connector under the fender that the tire can hit and cause what you are describing. You can see it real easy with a flashlight. Worth the time to check out cooldude
Mr.BubblesVRCCDS0008
« Reply #4 on: January 01, 2014, 05:01:51 PM »
Ground problems will cause all kinds of wierd stuff. Green wire is the ground check it at all bulbs or hook a new wire into the system and run to frame or battery post and se if it clears up.
« Reply #5 on: January 02, 2014, 08:31:42 AM »
He doesn't appear too concerned about this, but, the first place to look is the rear electrical connector at the rear fender section as mentioned. This problem is classic of a poor ground.
« Reply #6 on: January 02, 2014, 09:32:28 AM »
Yeah, another person signs up to ask his one question, then disappears without acknowledging people's help or showing he is putting in the effort to help troubleshoot his problem.
