November 25, 2025, 10:39:51 PM *
Author Topic: Hopkins #46255 tailight converter  (Read 1366 times)
hoosier jaybird
NE IN.
« on: December 31, 2013, 04:35:43 AM »
Well nuts; I bought a Hopkins 46255 converter and when it came the package said it was for trailers with a common brake/turn signal. My Escapade trailer has a separate tail/brake light unit from the turn signal unit. Has anyone used this particular converter in this type of a wiring set up? If so, what modifications have you done? The bulbs are not LED on the bike or trailer. Thanks Jay.
« Reply #1 on: December 31, 2013, 06:43:39 AM »
I did not use a converter for my trailer. But I did change out all the lights to LED.
PAVALKER
Pittsburgh, Pa
« Reply #2 on: December 31, 2013, 08:46:49 AM »
All the lights or just the ones on the trailer?   I thought if all LED it needed some kind of load balancer or something like that.
John
« Reply #3 on: December 31, 2013, 10:15:54 AM »
Just on trailer, when they were incandescent you could just barley see the brake lights, since I swapped out to LED they are really bright.
Brian
Monroe, NC
« Reply #4 on: January 01, 2014, 10:29:39 AM »
I suppose you need to know if the bulbs are one or two element type. When I converted my rear lights to run/brake/turn changing out the sockets to use the 2057 bulbs I too used a Hoppy convertor. The first one I purchased was not supplying enough voltage so the bulbs were dim and so were the LEDs not bright. When I called Hopkins they recommended I try the 46365 unit. This different unit worked great. The LED lights are bright now. So far so good now. Call them for help.
hoosier jaybird
NE IN.
« Reply #5 on: January 01, 2014, 11:58:42 AM »
Ok, thanks Brian. The tail/brake light unit has a 2 element incandescent bulb for tail and brake light function only. Then there is a separate unit for turn signal only which actually has a 2 element incandescent bulb which apparently only uses one element. I did call their tech help and the fellow I spoke to said the 46255 would not work for my set up and they did not have anything that would work for me. My lights are bright enough but I liked the thought of protecting the bikes lighting circuits. He did say that there are others that may be available. I wanted to run this past you guys for advice before I send it back, Jay.
Brian
Monroe, NC
« Reply #6 on: January 08, 2014, 03:19:50 AM »
So let me understand something. You are only talking about the trailer? If it is I apologize as what I did was just for the rear lights on the bike. Sounds like you may have to rewire the trailer. Just my two cents.
