November 25, 2025, 10:39:36 PM *
Author Topic: My petcock has no screen (99 Interstate)  (Read 1003 times)
rekit
Let's Go!
77532
« on: January 09, 2014, 08:27:37 AM »
Pulled it to drain old gas and mine is just a solid tube about 4-5" tall, and the reserve hole is just-A-HOLE (sorry, couldn't resist). Am I missing something? No wonder these petcocks fail......
Bought a brand new Z1 in 74 and sold it later to get a "family car" DOH!! My brother had a Kaw H1 at the time as well. Oh well, good times! Lately Mean Streak, CBX, Nighthawk 750, Connie, KZ1000, Yamaha TTR 250, KTM 250
« Reply #1 on: January 09, 2014, 08:35:42 AM »
The screen is still inside the opening of the tank bung.
« Last Edit: January 09, 2014, 09:00:25 AM by Ricky-D » Logged
rekit
Let's Go!
77532
« Reply #2 on: January 09, 2014, 08:50:20 AM »
I should 've taken a pic while i had it out. Anyone got a pic?
ptgb
Youngstown, OH
« Reply #3 on: January 09, 2014, 09:55:06 AM »
If you look at the hole in the bottom of the tank where the petcock goes in, I'm betting you will see a plastic ring up in there. Grab that with a pair of needle nose pliers and give it a gentle tug two or three times. That is the screen, it commonly stays in the tank when you pull the petcock out.
« Last Edit: January 09, 2014, 10:38:52 AM by ptgb » Logged
« Reply #4 on: January 09, 2014, 10:37:11 AM »
There is no specific "hole" for the reserve. It uses the same area of the tank, just draws fuel from the base of the pickup tube as opposed to the top of it.
« Reply #5 on: January 10, 2014, 02:49:52 PM »
They must have changed the screen tube.  My 98std screen tube comes out with the petcock and it's inlet tube.  Just a fine-mesh screen tube, maybe 5/8" diameter by 2" long IIRC, looks like SS screen made together with a nylon frame that surrounds the inlet tube.
snakemeister
Alabama
« Reply #6 on: January 12, 2014, 12:38:48 AM »
 I changed by petcock recently solely because it was 16 years old in an effort to avoid hydrolock.The screen stayed in the tank and had to be pulled out with needle nose pliers.
