February 08, 2026, 02:59:36 AM *
Author Topic: HEADLIGHT ISSUE  (Read 1371 times)
razrhawg
BRYANT,AR
« on: January 13, 2014, 05:10:45 AM »
I'VE NOTICED AFTER A RIDE MY HEADLIGHT IS DIM. I CAN TURN THE KEY OFF AND BACK AND IT'S BRIGHT AGAIN. ANY THOUGHTS?
WOOPIGSOOIE RAZORBACKS
Michvalk
Remus, Mi
« Reply #1 on: January 13, 2014, 05:22:59 AM »
I would think the bulb is bad. At least I would start there. Might check the fuse connections and other connections along the way. You didn't say if Interstate or Standard/ tourer, as the Interstate has relays in the OEM wiring, and the others do not. Just start with a new bulb and connections in the headlight area cooldude
snakemeister
Alabama
« Reply #2 on: January 13, 2014, 06:26:42 AM »
  I think you'll find that you have a bad connection getting hot.Bulbs either work or they don't.I'd check the lightbulb holder first and be sure the bulb is making a solid connection or if the holder has burnt spots on it from a loose connection.
« Reply #3 on: January 13, 2014, 06:52:20 AM »
If your Valkyrie is a Standard or Tourer, it could be your hi/low switch needs cleaning.  If you're so inclined, take apart the switch to clean it, or try giving the switch a good blast of contact cleaner through the gap around the edges of the rocker.
razrhawg
BRYANT,AR
« Reply #4 on: January 13, 2014, 07:04:28 AM »
thanks for the feedback, keep it coming. It's a 98 standard btw.
« Reply #5 on: January 13, 2014, 08:08:01 AM »
Are you using a higher wattage bulb? If so, then as mentioned it may well be your headlight socket starting to go bad(melt). Go to NAPA and get the one used for such applications and not worry any more.
« Reply #6 on: January 13, 2014, 09:14:55 AM »
Pretty unclear but, if your saying turn off from a running condition
to a stand still, sitting condition, it would seem to me that your
alternator may be failing. That and possibly a poor battery condition.
Mainly though I think it's more likely the alternator.
razrhawg
BRYANT,AR
« Reply #7 on: January 13, 2014, 10:56:12 AM »
NO STOCK BULB. WHAT CAN I GET AT NAPA?
« Reply #8 on: January 13, 2014, 10:58:23 AM »
BigBF's Tip:
Headlight The Best one is Sylvania Silver Star H-4 / 9003
whitestroke
San Pedro, Ca.
« Reply #9 on: January 13, 2014, 12:24:03 PM »
Napa sells 2 sockets that work. Get the HeavyDuty one. It won't melt.
http://www.valkyrieforum.com/bbs/index.php/topic,60162.msg576872.html#msg576872
« Last Edit: January 13, 2014, 07:30:21 PM by whitestroke » Logged
Minibike
Honda S90
Yamaha YL100
Bultaco 250 Matador
Bultaco 250 Pursang
Yamaha 250 YZ
Triumph 650 Bonni
Honda ATC 200
2 Kids 25 year break.
Suzuki GS 500
2003 VTX 1300S,
1998 Valk standard
2008 Goldwing
VegasF6
« Reply #10 on: January 13, 2014, 02:17:11 PM »
Actually bulbs do lose brightness  with age, and on occasion a hanging filiment can even cause a intermittent condition.
Not that I think thy is the problem here, just saying.
« Reply #11 on: January 13, 2014, 03:16:11 PM »
Maybe your idle speed is too slow.
I mean, hey come on, the bulb gets brighter when you shut it down.
« Last Edit: January 13, 2014, 03:17:53 PM by Ricky-D » Logged
razrhawg
BRYANT,AR
« Reply #12 on: January 14, 2014, 10:47:39 AM »
900 RPMS WHATS YOURS?
« Reply #13 on: January 14, 2014, 10:49:26 AM »
Between 900 -1000 is correct when warmed up.
razrhawg
BRYANT,AR
« Reply #14 on: January 14, 2014, 10:57:11 AM »
YEAH I KNOW. I THINK SOMEONE WAS JUST TAKING A SHOT AT ME. ACTUALLY YESTERDAY I CHECKED THE BULB CONNECTION AND EVERYTHING LOOKED GOOD. NOTHING BURNED. IT MAY HAVE NOT BEEN PUSHED ON ALL THE WAY. I DID THAT AND WENT FOR A SHORT RIDE AND GOT BACK AND THINGS SEEMED OK.  WILL TRY A LONGER RIDE SOON FOR THE ULTIMATE TEST.
