February 09, 2026, 12:57:36 AM *
Author Topic: My left rear turn signal is getting floppy. Need link to fix  (Read 1238 times)
thewoodman
Bradenton, FL
« on: January 15, 2014, 04:22:10 PM »
Somewhere in my memory bank, I recall a link to the repair sequence and diagram for fixing the sloppy rear turn signal stalks. Does anyone have that link?
Thanks in advance.
TheWoodMan
« Reply #1 on: January 16, 2014, 09:07:29 AM »
I am sure that if you get to the inside's you will find a way to tighten them up and most likely that would be from the bracket side as opposed to the light side.
Honda I am sure allowed for loosening and tightening the components.
98pacecar
« Reply #2 on: January 16, 2014, 11:29:43 AM »
Just take what ever screws or bolts you can get to, out.
This exposes more, n' so on,,, till ya get to da one you need.
Just removed and deep sixed dat whole assl.    last week..
Came apart in a jiffy..    cooldude
« Last Edit: January 16, 2014, 12:33:45 PM by 98pacecar » Logged
Valkpilot
What does the data say?
Corinth, Texas
« Reply #3 on: January 16, 2014, 11:32:22 AM »
Thanks in advance.
*** Edited to correct part reference ***
Perhaps this is a little more helpful:
If you have a 97 - 99 (with two screws in the turn signal lens,) then #14 in the diagram below is the likely culprit:
If that doesn't work for you, on all models the turn signals attach to part #19 in the diagram below.
You'll need to take apart the rear turn signal assembly and get at #11 in this diagram, which screws into #19 in the fische above.
« Last Edit: January 16, 2014, 01:17:17 PM by Valkpilot » Logged
VRCC #19757
IBA #44686
1998 Black Standard
2007 Goldwing
« Reply #4 on: January 16, 2014, 11:43:55 AM »
Valkpilot, I think you might have the wrong diagram shown.
Valkpilot
Corinth, Texas
« Reply #5 on: January 16, 2014, 12:40:29 PM »
If you're referring to the 2nd one, it's confusing because it shows both the rear and front signal housings but only the front mounts.  The 1st diagram shows only the rear mount, but not the housings.
VRCC #19757
IBA #44686
1998 Black Standard
2007 Goldwing
98pacecar
« Reply #6 on: January 16, 2014, 12:43:28 PM »
Having just disassembled, mine  I found dat screw #26 only holds on chrome trim piece... # 16
Not the blinker at all.   coolsmiley
Valkpilot
Corinth, Texas
« Reply #7 on: January 16, 2014, 12:58:39 PM »
You're right.  I'll edit my post.  What I was thinking of was the assembly on a 1997 - 1999 model where there is a screw on the back of the housing arm, #14 in the diagram below:
If he's got an early model, one with the two screws in the turn signal lens, this screw can come loose.   If that's not it, he's got to take the thing apart.
VRCC #19757
IBA #44686
1998 Black Standard
2007 Goldwing
Pete
« Reply #8 on: January 16, 2014, 01:03:19 PM »
If your Valk is a 97 model there is still an active Honda recall that may help.
See you closest Honda Service department, they can order it and install it at NO cost to you.
98pacecar
« Reply #9 on: January 16, 2014, 01:03:21 PM »
Absolutely,,,,, and if,,, #14 is already tight?  coolsmiley
#7 may just be so bagged out,,, dat it's time fer a new one...
Replaced a lot of those rubber blinker sections,,, thru da years....   Shocked
thewoodman
Bradenton, FL
« Reply #10 on: January 16, 2014, 06:55:51 PM »
I'm always amazed at the depth of knowledge of this group. Thanks all. The diagram gives me a peek inside and my scooter is a '97 Tourer, so I'll try that route as well. Must say that this would provide the opportunity to re-engineer the back end light/license plate setup that has always challenged my design style. I'd built a few custom Harleys over the years, so why not this simple re-design. Time will tell. Thanks again for the info.
TheWoodMan
thewoodman
Bradenton, FL
« Reply #11 on: January 19, 2014, 06:45:27 AM »
For anyone interested, I finally found what I was looking for under the known problems tab; the very first one was the rear turn signal loosening and there is a PDF with all the diagrams necessary. It took about a 1/2 hour to tear down, diagnose and repair the sloppy left rear stalk and all is well.
TheWoodMan
nsarago
« Reply #12 on: July 06, 2014, 08:45:50 AM »
What is number 6 and 7?  Is that the rubber part that holds the turn signal in place?  I need a new one for the right turn signal.  Does anyone know what this part is called and where I can find one?
