February 08, 2026, 02:59:28 AM *
Author Topic: Side Stand Nut  (Read 1430 times)
old grouch
Colorado Springs, CO
« on: January 17, 2014, 03:41:37 PM »
Does anyone know what size the nut (Part # 7 in the link below) on the side stand bolt is?  Is it a locking nut?  Mine is missing & I want to get one locally.  Don't want to order just one nut from HDL.  TIA.  Stan
 http://www.hdlparts.com/fiche_section_detail.asp?section=2552377&category=Motorcycles&make=Honda&year=1997&fveh=132667
09/11/01 NEVER FORGET!
klb
Hickory nc
« Reply #1 on: January 17, 2014, 03:50:02 PM »
The shop manual says the side stand lock nut is 10 mm thread diameter.
Also it torques to 22 Ft Lbs.
« Last Edit: January 17, 2014, 03:57:46 PM by klb » Logged
98pacecar
« Reply #2 on: January 17, 2014, 03:58:53 PM »
Look,,,,,,, at the list in this link...  Shocked    Shocked    Shocked
http://www.partzilla.com/parts/detail/honda/HP-90203-MF9-710.html
I think this same nut, has been used on all Hondas,,,, since christ,,,,,,,,, wuz a boy............     2funny
Looks like bout any,,,, honda side stand nut,, will work...   cooldude
old grouch
« Reply #3 on: January 17, 2014, 04:56:23 PM »
Thank you guys.  Looks like my dealer should have one of those in stock.
Old Geezer Richard
San Antonio , Tx
« Reply #4 on: January 20, 2014, 11:28:24 AM »
  Hey Old Grouch , when I replaced the bolt on the kick stand I also went and bought a spare bolt that connected with the spring underneath and a spare spring because that mickey mouse pot metal bolt underneath is known to BREAK when you least expect it to and wind up with no spring and NO KICK STAND FOR PARKING  .....  It happened to me luckily in my driveway after backing out , when I was pushing out the kick stand I heard a click and as I was getting off the bike while its leaning I noticed the kick stand pointing out to the side FLAT on the ground , my bike kept on leaning and leaning to the point of no return and on the ground .... Luckily I had help with my neighbor to get my Fat Lady up-right again ..... You can gas up while your sitting on your Valk , but when you get home and NOBODY is home then you have to be real inventive where to park your bike in gear against a wall , until you can get some jack stands on both side ..... Soooo now I cary a spare spring and bolt that holds the spring in place , just my .02 cents  ......  Thanks the Geezer   crazy2
old grouch
« Reply #5 on: January 21, 2014, 06:27:42 AM »
Geezer, thanks for the advice.  I have a spare spring & bolt.  The dealer didn't have the nut in stock.  The bike leans a lot.  More than I like.  Nothing is bent under there.  I thought maybe the missing nut would account for that.  Stan
Bone
« Reply #6 on: January 21, 2014, 06:39:18 AM »
Look under there again a cracked frame or bracket damage might not be visable on a lift.
Try looking with the sidestand supporting the bike.
