November 19, 2025, 05:45:24 PM *
Author Topic: Manifold Studs  (Read 1825 times)
2lane
« on: July 23, 2009, 02:24:52 PM »
Did something wrong and this got deleted.
Broke stud off half way and need to know how to get it out. Can get a hold of it. Does it screw out? Which way do the threads go,normal or backwards?
Warlock
Magnolia, Ms
« Reply #1 on: July 23, 2009, 03:58:27 PM »
It screws out the normal way. Might want to spray it with maybe wd40 or something like that. Also I would take a small hammer and barely tap the end and maybe this will shock it enough to make it come out better. JAT
David
X Ring
VRCC #27389, VRCCDS #204
« Reply #2 on: July 23, 2009, 04:36:26 PM »
Delisle makes a stud extractor that works really well.  Tap it onto the stud then unscrew it.  I was amazed it was that easy.  I found mine at Sears in the auto section of the hardware dept.
woefman
Arizona
« Reply #3 on: July 23, 2009, 11:07:29 PM »
If have a Welder You can Weld a Nut onto it . (done this many times)
I think you said not flush but for future referance the welding trick works on flush ones as well.
Also
Sometimes when flush  you will be surprised often a small Pick works just turn the stud out.
I've done this many times on Broken head bolts on ford tempo , ford taurus and ford aero star vans.
Honda` GL1800 Goldwing
Honda` GL1500 CT Valkyrie
Picture Links below:
http://picasaweb.google.com/azpicts
and
http://picasaweb.google.com/azpicts2
2lane
« Reply #4 on: July 24, 2009, 10:05:35 AM »
Hey Guys, I appreciate all the info. Going to start on it this afternoon. I'll let you know how it goes. Thanks Again.
Ferris Leets
Catskill Mountains, N.Y.
« Reply #5 on: July 24, 2009, 05:51:02 PM »
If you can get vise grips on it, soak with kroil or second choice WD-40.  If you have a propane torch heat up the stud some before you put on the oil.  Wait overnight if posible and then put the vise  grips to work.  And hope it does not break.
