February 08, 2026, 04:49:35 AM
Engine guard diameter
Topic: Engine guard diameter (Read 1130 times)
January 22, 2014, 08:55:44 AM »
Fellas what is the diameter of the engine guard tubing? I am not home where I can measure and am going to order some P-clamps for some auxiliary lights. Thanks in advance.
Re: Engine guard diameter
January 22, 2014, 09:02:54 AM »
The engine guards vary in diameter depending on where you are going to do an install. Out in the 3/9 Oclock positions, it is 1 1/8".
Assuming you would instal your clamps just outboard of the IS pods, 1 1/8" is probably right, but I would measure where you will instal just to be sure.
Last Edit: January 22, 2014, 09:05:39 AM by Jess from VA
January 22, 2014, 09:08:32 AM »
Thanks Jess but I should have clarified they are for my standard not my I/S and will mount on top of guard
January 22, 2014, 09:43:16 AM »
Except the pod mounts for IS, all Valk guards are the same (I'm 99% sure).
1 1/8" may do it, but measure anyway. Shimming too-big clamps sucks, and too-small are worthless. Right at the top, or an inch down may only be 1".
With a Std, I like something like these. Not enough room with the pods for IS. 3.5" spots will fit in the space better than the usual 4 to 4.5 inchers.
http://cyrilhuzeblog.com/2012/08/17/drag-specialties-3-12-high-power-led-spotlight/
http://www.motorcycle-superstore.com/62569/i/show-chrome-3-1-2-led-spot-light
http://www.motosport.com/cruiser/SHOW-CHROME-312-HALOGEN-SPOT-LIGHT
98pacecar
January 22, 2014, 11:26:39 AM »
Just laid a tape across mine (on a standard) directly below da air wings.
Reads,,, 1 1/8 ''
January 22, 2014, 02:20:20 PM »
Thanks guys got em ordered
