April 29, 2026, 05:32:34 PM *
Author Topic: Does Anyone Have An Extra Petcock Rebuild Kit, ( Diaphram)?  (Read 3932 times)
Bert AKA,Valkaholic
Back-N-Black
« on: January 28, 2014, 07:56:43 AM »
Or Does Anyone Know Where I Can Purchase The Diaphram To Repair My Petcock? I Know That I Can Buy The Complete Petcock From Honda But All I need Is The Diaphram . Any Help Would Be Appreciated.
Thanks,Bert
TJ
Lake Placid , Fl.
« Reply #1 on: January 28, 2014, 08:03:03 AM »
Hey Bert,
I talked to HDL a while back and they had them or could also get them... I had called about
them for a friend who rebuilds HD petcocks... Uses the same one....
98pacecar
« Reply #2 on: January 28, 2014, 08:17:45 AM »
http://www.ebay.com/sch/i.html?_odkw=honda+valkyrie&_sop=10&_osacat=10063&_from=R40&_trksid=p2045573.m570.l1313.TR0.TRC0.Xhonda+valkyrie+petcock+rebuild+kit&_nkw=honda+valkyrie+petcock+rebuild+kit&_sacat=10063
 Wink
Bert AKA,Valkaholic
Back-N-Black
« Reply #3 on: January 28, 2014, 08:34:43 AM »
Thanks TJ and 98 Pacecar , I Ordered A Repair Kit Off Of E-Bay As 98 Pacecar Posted. It Sure Is A lot Smarter Than Purchasing The Complete Petcock For $115.00 ++.
« Reply #4 on: January 28, 2014, 09:57:37 AM »
http://www.ronayers.com/FUEL-TANK-C176845.aspx
#5 on this page is a Petcock Cover Set from Honda.  It is what I have used several times.
Hay  Cool
« Reply #5 on: January 28, 2014, 11:25:06 AM »
That K & L kit used to be about 6 bux from HDL.
You are much better off with the coverset, which fixes more things than the K & L.
Flrider
Jack
Kissimmee FL
« Reply #6 on: January 28, 2014, 01:19:13 PM »
Bert
Just checked in and saw your post.
I guess I am a little late, I have one of those repair kits you could have had.
Good luck on your repair.  cooldude
Bert AKA,Valkaholic
Back-N-Black
« Reply #7 on: January 28, 2014, 04:23:16 PM »
Bert
Thanks Jack,
I Took  The Whole Prtcock Off Of My Red & Black Std. And Put It On My Interstate So I Could Ride It Until I Get The Repair Kit.
Bert AKA,Valkaholic
Back-N-Black
« Reply #8 on: January 28, 2014, 04:24:40 PM »
Hay  Cool
Thanks HayHauler,
I Will Save This Info. For Future Use.
Bert
Pappy!
Central Florida - Eustis
« Reply #9 on: January 28, 2014, 08:12:33 PM »
Thanks for the information..........ordered a set for stock.
Thunderbolt
Worthington Springs FL.
« Reply #10 on: January 29, 2014, 12:44:00 PM »
I was a holdout on these petcock repair kits.  I put two of them in the interstate until the last one just barely got me home from Citra one day.  They kept wearing out where the small metal piece in the center rubbed on the rubber diaphragm.  Once it gets a pin hole it won't hold vacuum any longer.  I did find out that if you plug the weep hole on the bottom of the petcock with the end of your finger or anything else it will get you home in case anyone else has this problem.  Anyway after buying and replacing two I finally relented and installed a Pingel manual petcock.  You just have to turn it off when you put it away.  Here is a link to one place that sells the correct part #.  The reserve is only about 1/2 gal. so keep that in mind.  I think John modified his to make the reserve more like normal. The outlet on the Pingel is not as large as the Honda and you need a clamp on the fuel line if you replace it with the Pingel.
http://www.leatherup.com/p/Cruiser-Motorcycle-Fuel-Petcocks/Pingel-Power-Flo-Chrome-Fuel-Petcock-Valve-for-Honda-Valkyrie/196790.html
I do have a spare petcock repair kit left in case Iris's bike needs it.  I think some of those non Honda kits didn't have all the parts in them, but if it has what you need then who cares right?
