February 08, 2026, 04:49:44 AM
nylos ring part #
Topic: nylos ring part # (Read 1010 times)
rekit
Let's Go!
77532
nylos ring part #
January 30, 2014, 05:59:13 AM »
Search came up empty. I found the Maryland Metrics page for the rings, and looks like grumpy uses a spacer dimension of 0.615 when using the nylos ring. Soooo, which ring? Thanks.
Bought a brand new Z1 in 74 and sold it later to get a "family car" DOH!! My brother had a Kaw H1 at the time as well. Oh well, good times! Lately Mean Streak, CBX, Nighthawk 750, Connie, KZ1000, Yamaha TTR 250, KTM 250
custom1
01 Interstate
SW Pa
Re: nylos ring part #
January 30, 2014, 11:36:49 AM »
It is 6204ZAV. Try a search for nilos not nylos.
Here is an old thread about it.
http://www.valkyrieforum.com/bbs/index.php/topic,28382.0.html
John
rekit
Let's Go!
77532
January 30, 2014, 12:12:05 PM »
Got it, thanks. Now, how much to trim off the spacer? I'm seeing .270, .280. Or just wait till I've got the parts and let the machinist measure the parts and sort it out? This measurement will affect my caliper to disc clearance, correct?
custom1
01 Interstate
SW Pa
January 30, 2014, 12:26:19 PM »
Without going back and reading the whole thread....I think I had .270 taken off. The consensus was .010 is a trivial amount and not to worry too much about it. Mine works fine. If it all fits in between the swing arm it will work. The caliper floats.
John
fantsybikr
O HI O
January 30, 2014, 02:27:29 PM »
.010 isn't much for this application imo ( I ground off exactly the width of the spacer) but it is a heck of a lot in others...I found reducing the size of the spacer was the easiest using a surface grinder with a magnet to holding it down..your machinist should have access to one.
VRCCDS 0252
VRCC 26284
GWRRA 329832
