November 25, 2025, 11:16:11 PM *
Author Topic: Side stand crossmember bent???  (Read 1088 times)
Curley Wolf
Curley Wolf in the Wind!!!
Kiln, MS / El Dorado, AR
« on: February 15, 2014, 11:18:35 PM »
Lick when I bounced down on steel culvert bent (rolled back) the crossmember on my '99 I/S. Saw Big BF's repair where crossmember was cut out and replaced but wondered if anyone has had experience trying to bend it back. Have my Valk at a local body shop and he suggested trying tying bike down and hydraulically bending (rolling) it back into position where stand will be functional. Thoughts?
Curley Wolf
« Reply #1 on: February 16, 2014, 04:50:29 AM »
Should work as far as getting into position, but it probably wont be strong enough to leave it like that.  If he gets it straight I think Id have him weld a piece of strong angle iron across the top and front edge.......you may need longer side stand mounting bolts but at least it would be strong
« Reply #2 on: February 16, 2014, 08:10:08 AM »
 cooldude Definitely needs to be reinforced after its straightened.
My rides:
« Reply #3 on: February 16, 2014, 03:30:04 PM »
You know about metal fatigue? Bending it back and forth, and you can end up breaking it.
Is this something you will be paying to have fixed, insurance, or ?
Personally, I would bend it back, Once only. If I was to ever hit it again, and bend it, I would do the proper repair. I don't feel the job is too hard, but time consuming and requiring a few special items (welder).
blotar
VRCC #32549 VRCCDS#0237
Crosby, Texas
« Reply #4 on: February 18, 2014, 07:44:42 PM »
I traded for a second Valk that needed  a  clutch. Though I was getting a good deal... Found out that the PO had hit something and bent the cross member. Put the Kickstand bracket back on and hit it with a 4 lb hammer many times and got nowhere fast. I ended up putting a couple of shims under the trailing edge of the kickstand until it was extended to the right place and since I couldn't hurt it with the four lb hammer, I guess it is strong enough to hold the kickstand.
Blotar
http://vrcc.photostash.com/vrcc_32549/VisitedStatesMap3.jpg
1998 Valkyrie CT
1995 V-Max [img width=347 height=175]
1995 Yamaha Virago 1100
1994 Suzuki GSX 1100 G
1995 Honda Shadow 1100
1994 Honda Magna 750
196? BSA Hardtail
1973 K3 Honda 750
1964 Allstate 250
Tundra
2014 Valkyrie 1800
Seminole, Florida
« Reply #5 on: February 19, 2014, 02:53:20 AM »
Blotar
Sounds like it was possibly trailered with the sidestand down?
