December 31, 2025, 09:08:39 AM *
Author Topic: Front brake pad retaining clips  (Read 2599 times)
NEHI
« on: July 26, 2009, 03:45:15 PM »
    Where do I buy the clips that hold the front brake pads inplace? My left back clip is missing causing the brakes to clunk when braking. Honda wants $109.00 for a clip that should cost .95 because you have to purchase the entire mount that holds the caliper on.
« Reply #1 on: July 26, 2009, 04:34:19 PM »
Yeah, that's not right.  You must have not used the correct part number.
Here ya go.  Part number three, or part number five, you pick.
http://fiche.ronayers.com/Index.cfm/Module/Main/TypeID/26/Type/Motorcycle/MakeID/1/Make/Honda/YearID/41/Year/2000/ModelID/7142/Model/GL1500CT/GroupID/309317/Group/REAR_BRAKE_CALIPER
Probably less than three dollars either.
« Reply #2 on: July 26, 2009, 04:36:53 PM »
Sure I saw rear brake!   But here's the front caliper.
http://fiche.ronayers.com/Index.cfm/Module/Main/TypeID/26/Type/Motorcycle/MakeID/1/Make/Honda/YearID/41/Year/2000/ModelID/7142/Model/GL1500CT/GroupID/309313/Group/FRONT_BRAKE_CALIPER
Part six and eight.
You'll figure it out!
NEHI
« Reply #3 on: July 26, 2009, 06:21:31 PM »
   Thanks for the link, Honda does not offer that part without buying the whole bracket! I guess on a motorcycle that never brakes down they have to make money someway LOL.
   Thanks again!!!!!!!!!!
Flyingfree
« Reply #4 on: August 23, 2019, 04:28:27 AM »
Are the pads supposed to snap into these clips or just shake around on the one pin holding them in? Gettling a lot of rattle when riding and I know it is the brake pads not pulling away from the rotors enough. Might do a brake fluid flush and see if that helps with the release. I understand these brakes do not have a forced release, just a pressure bleed when you release the brake handle.
« Reply #5 on: August 23, 2019, 06:50:03 AM »
Pinwall cycle (salvage)
https://pinwallcycle.com/advanced_search_result.php?__Secure-osCsid=7f885e4c9261afd4c45d6b4f998fd360&keywords=valkyrie+brakes
It's a crapload easier to just call them and ask for what you want, than plod through their website for two days.
mello dude
Dayton Ohio
« Reply #6 on: August 23, 2019, 06:54:04 AM »
Not sure what you mean by "Honda".... the clips are available for around 4 bucks and change... Cool
Ramie
2001 I/S St. Michael MN
« Reply #7 on: August 23, 2019, 08:03:07 AM »
https://www.partzilla.com/catalog/honda/motorcycle/1998/gl1500c-ac-valkyrie/front-brake-caliper
mbramley
Painesville Ohio
« Reply #8 on: August 26, 2019, 11:15:09 AM »
 I went thru the same thing . If you do a search for different models and years you con find the same clip sold separately for a lot cheaper. I posted about it back then with year/model.
