February 08, 2026, 08:32:49 AM *
Author Topic: Missing Tooth  (Read 1612 times)
svocarl
South Louisiana
« on: February 23, 2014, 06:52:12 AM »
Need to hear some options on what to do. After the dreaded Hydrolock I had 2 teeth missing on my idle gear. After removing the cases to change the idle gear I can only find one of the broken off teeth. I even removed the gears to look for it to be hidden. I tried to use a borescope and even a magnet on a stick. Inspected the oil that came out all with no luck. Was wondering with the front case removed how much of the sump can be Inspected. I don't want to split the case . What do you think of leaving the missing tooth in? I don't see it doing any harm.
« Reply #1 on: February 23, 2014, 06:59:17 AM »
I would definitely locate the missing tooth.  Only bad things can happen if it gets caught in moving parts.
« Reply #2 on: February 23, 2014, 07:16:22 AM »
Quote from: Skinhead link=topic=64956. :-\msg631926#msg631926 date=1393167557
Sorry for your misfortune!   Undecided  Please keep us posted.
My rides:
Joevalk
Santa Fe, Texas
« Reply #3 on: February 23, 2014, 08:38:25 AM »
When I bought my bobber project, it had a missing tooth also. When I tore it down the tooth was laying in the bottom when I pulled the rear case off. The bike was running a while after the hydro lock happened.
VRCC#32720
1999 Grn/Silver Interstate
1500Rider
« Reply #4 on: February 23, 2014, 02:15:04 PM »
When you pull off the rear case, take a look along the bottom, under the gears. There is a length of chain guard in there as sometimes the missing tooth can be jammed up behind or underneath that guard. That's where I found the tooth that had come off my gear. It was lodged in there pretty tight so it was out of the way but I'm glad I found it. No telling if/when it would have come loose and cause all sorts of problems.
1990 Honda VFR750F
1997 Honda Valkyrie GL1500 Tourer
1998 Honda Gold Wing GL1500 SE
art
Grants Pass,Or
Grants Pass,Or
« Reply #5 on: February 23, 2014, 03:18:38 PM »
I'm not sure it can be done but I would drain the oil and get some kerosene and try to flush the inside from the starter opening to see if it will come out the drain hole before splitting the case. You got nothing to lose and maybe you will get lucky. It sure beats a tear down.
whitestroke
San Pedro, Ca.
« Reply #6 on: February 23, 2014, 05:08:56 PM »
Maybe a magnet epoxied to a piece of tie wire, and you could fish around for it.
Minibike
Honda S90
Yamaha YL100
Bultaco 250 Matador
Bultaco 250 Pursang
Yamaha 250 YZ
Triumph 650 Bonni
Honda ATC 200
2 Kids 25 year break.
Suzuki GS 500
2003 VTX 1300S,
1998 Valk standard
2008 Goldwing
pancho
Bonanza Arkansas
« Reply #7 on: February 23, 2014, 06:23:10 PM »
Then after the magnet and the tooth were lost in the case, it would be a good time.....  drug run .....
uturn
bayou vista, texas
« Reply #8 on: February 23, 2014, 09:35:41 PM »
the bike i just put on the road had 5 missing from the starter gear, four off the idler and chunks from the case heaven knows if i got them all. 1,000 miles later nothing bad has happened...
« Reply #9 on: February 24, 2014, 05:06:31 PM »
The rear cover of the engine, which houses those gears/teeth, has an oil passage plugged by a "screen". No teeth can go from the rear cover, into the main engine (the split case).
The rear cover has been removed while in the bike by others. But personally, I have removed the engine, and I would rather do that and have full un-impeded access to the rear of the engine for the repair job, than to do it while it is within the bike frame.
uturn
bayou vista, texas
« Reply #10 on: February 24, 2014, 05:16:32 PM »
how in the h e double hockey sticks do you get cases off without pulling the motor??? it seemed to me much easier to drop it and have better access...
svocarl
South Louisiana
« Reply #11 on: February 24, 2014, 05:46:49 PM »
Thanks for all the ideas. The engine is off on my work bench. The screen filter was in the first cover in the clutch area. Their was no screen in the second cover or bay with all the gears , it drained directly into the oil pan. Would still like to know if I take the frount engine cover off can I see to the back of the engine , so I can Inspect for missing tooth.
Red Diamond
Beaumont, Texas
« Reply #12 on: February 24, 2014, 05:59:00 PM »
If the little black screen filter was in place, the missing tooth should have been in the clutch case area. There is no way for the metal to get  pass that screen filter into the crank case, probably is no need to remove the front cover. Remove all the metal shrapnel you can find, look behind spaces that may be able to hide metal pieces. If you really want to be on the safe side, remove the clutch and clean it up of metal.
uturn
bayou vista, texas
« Reply #13 on: February 24, 2014, 07:36:34 PM »
wow...a workbench to have the valk engine on to work on it. now THATS living. i tore mine down on the garage floor. that sucker is heavy when it rolls off the jackstand onto your leg.
http://i1333.photobucket.com/albums/w622/bitikofer72/image_zps9a43401c.jpg
uturn
bayou vista, texas
« Reply #14 on: February 24, 2014, 07:40:37 PM »
why are these darn photos always upside down....sorry, but you get the idea...
« Reply #15 on: February 24, 2014, 08:04:12 PM »
Dunno but I was wondering Grin
svocarl
South Louisiana
« Reply #16 on: February 25, 2014, 06:02:17 AM »
Thanks again for everybodys help. The Idle gear is in the 2nd chamber on the other side of the screen. The screen seems to be for clutch particles . I found one tooth wedged or stuck in the side in the 2nd bay that has a clear path for the oil to drain back to the engine. The 2nd chamber has all the gear stuff the 1st chamber has the clutch. Still would like to know if the frount case is removed is their a path to the rear to find this missing tooth.
« Reply #17 on: February 25, 2014, 06:57:31 AM »
Got to HDL and look at the exploded views on their part fische,  Maybe that will answer your question.  From looking at the block and transmission cover views, I would say no.
http://www.hondadirectline.com/OEMpartfinder.htm#/Honda/GL1500CF_A_(99)_MOTORCYCLE%2c_USA%2c_VIN%23_1HFSC410-XA000001/CYLINDER_BLOCK/GL1500CF-99-A/2Y14MBYXMBY4E1500A
« Reply #18 on: February 25, 2014, 09:40:04 AM »
After looking at this fiche, I would say no also.  It seems that there are parts of the casting that create different compartments and that you could not see from the front to the back.  But, I have not seen an engine taken apart that far before.
Hay  Cool
