February 08, 2026, 10:23:31 AM *
Author Topic: Propeller Shaft Oil Seal  (Read 1368 times)
Wewaman
Dead Lakes Cruiser
Wewa, Fla.
« on: February 26, 2014, 04:26:43 AM »
I got a new Propeller (Drive) Shaft and pinion cup along with the Oil Seal for the Pinion cup and I need to know if I am supposed to pack the oil seal with grease ?  If so do I just fill in the gap where the spring is inside the seal ?  Undecided
As soon as I get that little tid bit of information I will be on my way to re-assembly... cooldude
Thanks for your input,
 Wewa
If you please God it doesn't matter who you displease   but if you displease God it doesn't matter who you please Smiley
« Reply #1 on: February 26, 2014, 04:43:35 AM »
I'm no expert, but I didn't pack mine. I did lightly put some on and wiped off just so it wouldn't grab on any thing
Bone
« Reply #2 on: February 26, 2014, 04:48:16 AM »
This is from the manual, I didn't pack mine.
Pack 2 g (0.08 or) of molybdenum disulfide grease into the
plnion joint spline.
Install the drive shaft into the pinion joint until the stopper ring
seats in the pinion spline groove.
NOTE
Make sure that the stopper ring is seated properly by
pulling on the drive shaft lightly.
Be careful not to damage the drive shaft oil sea[.
Wewaman
Dead Lakes Cruiser
Wewa, Fla.
« Reply #3 on: February 26, 2014, 02:48:47 PM »
 cooldude Thanks so much..  cooldude
« Reply #4 on: February 26, 2014, 04:44:14 PM »
I greased this new one up when I installed it. Less than a tire later, it had come out
of the pinion cup and the cup and drive shaft were ruined...
Rio Wil
« Reply #5 on: February 26, 2014, 04:57:16 PM »
The failure of the seal is not what caused the shaft/cup failure.  It is the other way around.  The cup and shaft start to heat up from friction caused by lack of lube and the heat destroys the seal.
This comes back to----- is the shaft/cup lubed with final drive fluid coming through the two holes in the cup or is it lubed by the grease installed at assembly?????
« Reply #6 on: February 26, 2014, 05:25:35 PM »
I know I wasn't putting enough grease in the pinion cup at assembly, because I weighed it last
time... it is time for a new tire... I'll see what's in there now soon...
Of course, all greases don't weigh the same amount, but "four quarters worth" is how
much grease the Honda manual calls for...
-Mike "the grease is in one of those creamer cups the people at work adulterate their coffee with"
Wewaman
Dead Lakes Cruiser
Wewa, Fla.
« Reply #7 on: February 27, 2014, 07:15:34 PM »
Good info to have,  I am off tomorrow so I will get to work on my Valk .  Wooooo Hooooo cooldude
