February 08, 2026, 10:23:30 AM *
Author Topic: CT clearances  (Read 1591 times)
Wewaman
Dead Lakes Cruiser
Wewa, Fla.
« on: March 01, 2014, 02:49:02 PM »
CT - General Altimax 205/60r -16   how much clearance should I have on the right side between tire and swingarm?
I only have maybe 1/16 space with no rider on it.
First CT for me so not sure that will work.
Please advise,
Wewa
If you please God it doesn't matter who you displease   but if you displease God it doesn't matter who you please Smiley
Bone
« Reply #1 on: March 01, 2014, 02:56:08 PM »
Mine has always been a credit card thickness. My first CT got a few scuffs on the sidewall. Upped the air pressure a few #'s and all was ok.
« Reply #2 on: March 01, 2014, 03:38:43 PM »
Had the same make and size on my I/S. 3 credit card thickness's between sidewall and swing arm. Recommend 34 36 P S I to start. Make SURE your gage is accurate. And the 3 credit cards are NOT jammed in there. Could not get the 4th thickness BUT I never rubbed sidewall. RIDE SAFE.
Challenger
Posts: leet
« Reply #3 on: March 01, 2014, 03:52:14 PM »
Maybe two credit cards on mine, looks close but does not rub, Remember, the clearance at the swing arm level will not change no matter how many people you put on your bike.
Wewaman
Dead Lakes Cruiser
Wewa, Fla.
« Reply #4 on: March 01, 2014, 04:46:35 PM »
OK that makes me feel better I have about 2 cc thickness
Thanks for the tire info cooldude
Wewa
« Reply #5 on: March 01, 2014, 04:50:43 PM »
Like they said, very close to swingarm usually will never touch.
But I hope you did the nutcages, it will touch them, and moreso with a passenger.
Wewaman
Dead Lakes Cruiser
Wewa, Fla.
« Reply #6 on: March 01, 2014, 05:19:49 PM »
Jess , yes I did the nut cage mod but I was a tad bit concerned about clearance so I bought a 1/2 inch longer bolt and nylock nut and installed it from the underside out.  Now  only the bolt head is under there.  Of course I have not put the shocks back on so there was pretty much NO clearance when the bike was fully lowered. I guess when the shocks are installed it will keep the bike higher up above the bolt.
« Reply #7 on: March 01, 2014, 05:26:45 PM »
I guess when the shocks are installed, it will keep the bike higher up above the bolt.
You mean the shock will keep the bolt head above the tire?
Well no.... the top outside of the sidewall will overlap the bolt head, but should not rub if the nutcage is gone, even with a passenger.  If it does rub, on one side (rare) there is always the fender washer mod, but very unlikely.
« Last Edit: March 01, 2014, 05:29:57 PM by Jess from VA » Logged
uturn
bayou vista, texas
« Reply #8 on: March 01, 2014, 05:36:58 PM »
nice choice! everyone down here runs the g.a. at 44psi and my swingarm is about one hair width...
Michvalk
Remus, Mi
« Reply #9 on: March 01, 2014, 05:59:13 PM »
Mine run close enough to knock the dust from the sidewall. Never actually touched though cooldude
Wewaman
Dead Lakes Cruiser
Wewa, Fla.
« Reply #10 on: March 01, 2014, 06:49:37 PM »
 so I should be able to use the original bolt and square nut and be ok with the nut  cage mod ?
« Reply #11 on: March 01, 2014, 07:14:46 PM »
No, that OE square nut (to be held inside the cage) is a big fatboy and you don't want it there. (It might be OK, or it might not, and only riding two up for hours will tell for sure, if it rubs it will score your outer sidewall near the tread)
All I did was use the original bolt, but went to a single thin hex nut (w antisieze).  Many use a carriage bolt (smooth domed head) from the inside out, then add decorative acorn nuts outside the fender strut, but I didn't.  The one small thin nut has been tight on both sides for years with no issue for me, it doesn't really carry any major load.
« Reply #12 on: March 02, 2014, 08:40:06 AM »
I didn't need the nutcage mod but did it anyway. I use stock bolt & nut with no problem. If this is your first car tire don't get freaked out with the low speed handling. You'll get used to it pretty quick. Good luck cooldude
dr.danh
« Reply #13 on: March 02, 2014, 10:45:47 AM »
3/16 tire rounded clearance to swing arm. 205-60-16. Used feeler gage. and 3/16 black dust cover edge to machined wheel groove edge.
uturn
bayou vista, texas
« Reply #14 on: March 02, 2014, 04:02:34 PM »
on the '98 the original big square nut and bolt worked fine, but i have the saddlebag racks so i know the bolt doesnt go all the way through that nut. no rub, i ride two up...im 245 (uugh...) and my usual gf is...well...i like her....
Wewaman
Dead Lakes Cruiser
Wewa, Fla.
« Reply #15 on: March 03, 2014, 06:14:38 AM »
and my usual gf is...well...i like her.... Grin Grin
Well said or I guess NOT said.. 2funny
« Reply #16 on: March 03, 2014, 07:05:56 AM »
On second thought, leave the big fat nut on there. If it did rub, it's not that bad to change.
Preparing for my first CT, I went out of my way to create space.  A 205 does fill up the space pretty well.
The big nut would be much easier to wrench on later (esp reaching underneath),  if necessary.
Wewaman
Dead Lakes Cruiser
Wewa, Fla.
« Reply #17 on: March 03, 2014, 09:58:39 AM »
Thats what I did left it on there, it is pretty tight but I will keep a close check on it after I get it running.  Waiting on my petcock rebuild kit and screen kit to arrive
thanks for the feed back, it is a Greatly  appreciated ,
Tony  cooldude
Cliff
Manchester, NH
« Reply #18 on: March 05, 2014, 05:09:44 AM »
I was able to stop the nutcage from rubbing with only doing the "washer mod"
VRCC # 29680
PhredValk
Edmonton, Alberta, Canada
« Reply #19 on: March 05, 2014, 11:26:53 PM »
I have a Falken Ziex ZE-512 205/65R-16 on the rear. It clears the swingarm on the right by one credit card. It has always rubbed on something in certain situations. I was worried at first, but after 30K miles I don't worry about it any more. It's just a scrubbed spot on the right sidewall that has deleted the manufacturers lettering. No biggie.
Fred.
VRCCDS0237
