February 08, 2026, 08:32:42 AM *
Author Topic: valkyrie interstae hitch  (Read 1123 times)
rm
« on: March 07, 2014, 10:22:59 AM »
need  to locate the person that posted the drawing  with the dimensions some time ago on a hitch that they were making for their valkyrie interstate. trying to get one made.hicth doc only has chrome one and will not sell one before being chromed and i want to powder coat the one i make.also perfer one that is bolted together instead of welded as hitch doc does. thanks.
KSDragonRider
Salina, KS
« Reply #1 on: March 07, 2014, 10:42:48 AM »
all of the drawings that i have come across are just a tad off in one way or the other, and had to be messed with.
Get you a piece of cardboard, and to take a look at your bike. make a couple templates, then draw it up.
it is not that hard, then you can even take the templates to a laser cutter, and they will turn it into steel
Dalen & Shay -> Salina, KS
VRCC Member #33950
PhredValk
Edmonton, Alberta, Canada
« Reply #2 on: March 07, 2014, 10:57:48 PM »
This is what I have for plans, my hitch came from Quebec...
Fred.
VRCCDS0237
firea100
East China Mi.
« Reply #3 on: March 09, 2014, 05:14:14 AM »
How thick is the material? Any idea if it will fit a standard?
Thanks, Larry in East China Mi.
Novavalker
99 Interstate/2017 Goldwing
« Reply #4 on: March 09, 2014, 06:11:44 AM »
3/8" thick.
It should fit a standard.
Mr.BubblesVRCCDS0008
« Reply #5 on: March 09, 2014, 03:38:31 PM »
My is 1/4" X 2" flat bar and never had a problem with pulling a trailer. Remember these are pretty light trailers. Proper tongue weight is a key to a good pulling trailer.
tank_post142
south florida
« Reply #6 on: March 09, 2014, 03:43:43 PM »
i posted drawing a few years ago, but, would not know were to find them now.
found one:
« Last Edit: March 09, 2014, 03:49:04 PM by tank_post142 » Logged
I got a rock Sad
VRCCDS0246
« Reply #7 on: March 09, 2014, 09:33:47 PM »
I was going to add on either a 1/4" rod or tubing to the side and weld it on to stiffen it up. Also the same to the lower 2 bends to add additional welding, again for support and bracing.
I figure 1/4" flat bar would not be stiff enough, and didn't want the side brace to flex.
jmann
Mesa,Az.
« Reply #8 on: March 09, 2014, 09:55:35 PM »
Use 3/8" and it won't flex. I built mine out of that and trust me it's plenty strong.  cooldude
TJ
Lake Placid , Fl.
« Reply #9 on: March 11, 2014, 07:43:22 AM »
There are two hitches on the want adds for sale... They are all the same and will fit any year or model....
