November 26, 2025, 12:05:09 AM *
Author Topic: IS Desmog  (Read 715 times)
PhredValk
Edmonton, Alberta, Canada
« on: March 15, 2014, 07:02:46 PM »
I started my desmog today and have run into some snags. I have stuff not in the pix in the desmog instructions in Shoptalk. I think it's because she's a California bike. There's a doodad to the rear of the Pair valve connected by a hose:
The foreward part of this gizmo is another with two hoses, labeled 6:
that lead to a T connecting the rear two carbs on each side:
I'm thinking of removing the device and just plugging the hoses. Has anyone doe this, and could I run into problems because of it?
Fred.
VRCCDS0237
PhredValk
« Reply #1 on: March 15, 2014, 08:09:00 PM »
OK, I found the other Desmog item that shows these things removed, but it doesn't say what to pull or what to plug. Any suggestions are appreciated.
Fred.
VRCCDS0237
Wewaman
Dead Lakes Cruiser
Wewa, Fla.
« Reply #2 on: March 15, 2014, 09:41:25 PM »
I can only tell you what I did to mine.  I just got her back together so I don't know if what I did works  2funny
If you go to shop talk and read "Removing the smog"  you will see this link for CA bikes
CA De-Smog notes by Tim Skelton
It shows that you leave the two #6 hoses because they go to the Air Vent rails,
on the diaphram that they connect to you plug the small port with a vac cap and you buy a crankcase filter and push it onto the bigger port of the diaphram.
Purolator B13153 or Fram BA3812
also it shows that you have a 6 way T that you run vac hoses to all the carbs and then it says to PLUG this T, there is a pic of that.
I just did away with all the hoses and put Vac caps on all the Carb ports, I mean if I'm plugging the T why do I need all those hoses?  Much cleaner.. cooldude
 On the #3 carb there is a second port on the bottom side that needs to be plugged also.
Hope this help,
Wewa
If you please God it doesn't matter who you displease   but if you displease God it doesn't matter who you please Smiley
PhredValk
« Reply #3 on: March 15, 2014, 10:34:17 PM »
Thanks, Wewa, I saw that and didn't realize it was a link. I was going to plug the '6' hoses but now will leave them alone. I'll get rid of the 6-way T and cap the individual hoses out of the way. I'll be keeping everything so that if I have problems I can put it all back.
Fred.
VRCCDS0237
