November 25, 2025, 11:48:21 PM *
Author Topic: Dan Marc  (Read 1833 times)
Bota58
Oakland City Indiana
« on: March 27, 2014, 02:20:31 PM »
Hi,I was thinking about installing a Dan Marc fuel valve but the orfices look pretty small anyone had any problems with fuel flow with one of these.
Life's Journey is not to arrive at the grave safely in a well preserved body but rather to skid in sideways totally worn out  shouting holy cow what a ride!
« Reply #1 on: March 27, 2014, 02:24:40 PM »
I have one on MGM, both as a 2 wheeler and as a Trike with no problems.
I have the free flowing, don't ask the part # as I have tossed those receipts in the grinder.
I've had it on about 4 or 5 years now.
It pulls like a scalded dog all the way out over the $$ mark.
Flrider
Jack
Kissimmee FL
« Reply #2 on: March 28, 2014, 06:18:14 AM »
No problems at all, have them on two Valks and all is good.
« Reply #3 on: March 28, 2014, 06:55:28 AM »
cooldude I also have them on two Valks, no issues. Just make sure that all the gas lines are downhill, gravity.
My rides:
Bota58
« Reply #4 on: March 28, 2014, 09:01:26 AM »
Ok Thanks guys I've just about got the carbs back off to put the stock mains back in,gonna try maybe 2 turns out with the pilots as that kinda in the middle of what everyone is telling me.Stock mains 38slows and cobras with baffles
deadwood
Albuquerque New Mexico
« Reply #5 on: March 28, 2014, 03:57:47 PM »
http://www.valkyrieforum.com/bbs/index.php/topic,65798.0.html
Going to put the non-filter version on this weekend and see what happens.
Skydive New Mexico Motorcycle Club, Touring Division.
« Reply #6 on: March 28, 2014, 04:32:42 PM »
I have one on my interstate, but it is used to control my air horn.  You can just make it out on the right of the resevoir.
Bota58
« Reply #7 on: March 28, 2014, 06:01:27 PM »
Yeah that's different,I've got the carbs back together did pilots 2 1/4 turns have the Dan marc all hooked up except for the wires will finish tommorrow did get the airbox back on should hear it run tommorrow .
« Reply #8 on: March 28, 2014, 06:39:28 PM »
Bota58 be sure and sync your carbs.
My rides:
Bota58
« Reply #9 on: March 28, 2014, 07:18:02 PM »
Ok but what's the best way to do it.
« Reply #10 on: March 29, 2014, 05:16:52 AM »
There are different approachs, do a search and you will find a lot of useful information . "How to" is also in the service manual. Have you downloaded  a copy at Dag's site? I use a large faced vacuum guage to sync carbs.
My rides:
Bota58
« Reply #11 on: March 29, 2014, 05:28:42 AM »
Ok Thanks
« Reply #12 on: March 29, 2014, 05:29:42 AM »
The service manual download:
http://www.valkyrienorway.com/download.html
My rides:
Bota58
« Reply #13 on: March 29, 2014, 06:44:21 AM »
Ok Thanks Salty1
« Reply #14 on: March 29, 2014, 08:52:51 AM »
Skinhead, I'm surprised on that, due to the orifice size difference between the Dan-Marc Solenoid and the Hadley one.  Obviously it works, or you wouldn't be using it.  I recently replaced my Hadley solenoid on my Hadley air system powering my Grover horn (and my air shocks, tire filling hose).  That was after it started leaking after a dozen years or so.  Bought a cheapo solenoid on ebay from China, leaked internally from the start.  Bought another Hadley and it works fine.  Found it at a decent price too.
Oh yeah I also have a Dan-Marc on both Deerslayer and my Honda lawn tractor.  Normal one, no filter.  Installed for maybe a dozen years. Works fine, never a problem.  Mine is powered by a relay wired as a latch with hidden pushbutton and LED indicating on, so it also functions as an anti-hijack / theft device.
http://www.horseapple.com/Valkyrie/Tech_Tips/Fuel_Shutoff/fuel_shutoff.html
« Last Edit: March 29, 2014, 08:55:09 AM by MarkT » Logged
« Reply #15 on: March 29, 2014, 08:54:43 AM »
Oh yeah I also have a Dan-Marc on both Deerslayer and my Honda lawn tractor.  Normal one, no filter.  Installed for maybe a dozen years. Works fine, never a problem.  Mine is wired, powered by a relay wired as a latch with hidden pushbutton and LED indicating on, so it also functions as an anti-hijack / theft device.
I used the Dan Marc as a proof of concept as I had one laying around waiting to be installed on the fuel system.  Since it worked on the air horn, I never installed a fuel shut off.  Do you have a link to the Hadley valve?  (I'll do a search for it) but so far things are working fine.  When I first looked for solenoid valves everything that came up was too big and/or too expensive.
« Last Edit: March 29, 2014, 09:25:40 AM by Skinhead » Logged
« Reply #16 on: March 29, 2014, 09:12:52 AM »
I used the Dan Marc as a proof of concept as I had one laying around waiting to be installed on the fuel system.  Since it worked on the air horn, I never installed a fuel shut off.  Do you have a link to the Hadley valve?  (I'll do a search for it) but so far things are working fine.  When I first looked for solenoid valves everything that came up was too biag and/or too expensive.
It was actually JC Whitney selling it on ebay, price was higher than I remember at $38 with shipping free. It is item #370915219698. I see it's still listed under that number at ebay.  That price is $20 off list.
« Reply #17 on: March 29, 2014, 09:33:42 AM »
When I built my system I used a modified Pickup AC accumulator as it had a 40psi pressure switch on it, I wired the pressure switch to 2 relays that control when the compressor shuts off (40psi) so I'm running  a relatively low pressure system.  I'm using a $25 harbor freight compressor, bought the horn for $10 at a swap meet, so I got about $75 tied up in in it.
Bota58
« Reply #18 on: March 29, 2014, 10:58:00 AM »
Ok got everything hooked up and ran great for about a 1/4 mile then starts to act like it's running out of gas,let it sit for awhile and it runs again,I wired the dan marc to the wires on right side of bike one is white with black stripe and the other is green with gray dashes,double checked and my flow is going in the right direction,any ideas?
« Reply #19 on: March 29, 2014, 11:05:27 AM »
Are all hoses going down with no incline anywhere in the lines. Carbs are gravity fed.
Bota58
« Reply #20 on: March 29, 2014, 11:12:31 AM »
Yeah I made sure they were all going down and checked for kinks also.
« Reply #21 on: March 29, 2014, 11:15:18 AM »
I thought about putting one on my bike a while back but hear to many people that have had problems.
« Reply #22 on: March 29, 2014, 12:26:26 PM »
Which model of Dan Marc did you install? The ones with filters have been a problem for some (model 152 maybe). When they change it out for a non filtered model things are fine.   Undecided  I've used the non filtered type and have had no issues.
My rides:
Bota58
« Reply #23 on: March 29, 2014, 01:28:31 PM »
Yeah mines not filtered.
« Reply #24 on: March 29, 2014, 02:27:02 PM »
What kind of shape is your petcock in? When you put your tank back on, did you make sure the vent line didn't get kinked?
My rides:
Bota58
« Reply #25 on: March 29, 2014, 03:36:51 PM »
I'm going to cool off and check it out better tommorrow maybe lift the tank and double check.when I first took off it sure ran good for about a 1/4 mile pulled real good a lot better than when I got it back from the dealer.
« Reply #26 on: March 29, 2014, 07:00:02 PM »
Take your spare key, open the gas tank cap, and go for a rdie with it open.   NO problem with running, even after your 1/4 mile, you have a kink in your vent line.
If you want to leave with the key in the closed tank lid, and wait for the staggering, pull off to the side of the road and open the gan tank lid.   If you hear a phoose, the vent line is kinked.
No biggie, just take the bolt out the the rear of the tank and raise it enough to get a small piece of wood under it and then pull on the vent hose at the bottom.   It should straighten out.   Put the bolt back in and presto, you fixed it.
Bota58
« Reply #27 on: March 30, 2014, 06:02:23 AM »
Ok I hate to sound stupid but where's the vent line,I was thinking on the petcock there was just vaccum and fuel.
« Reply #28 on: March 30, 2014, 07:48:13 AM »
The tank vent line is the small one at the back of the tank. Behind the petcock.
Bota58
« Reply #29 on: March 30, 2014, 08:03:45 AM »
Yeah I don't even remember seeing one or taking one off could someone have eliminated it or will it not breathe without it.
« Reply #30 on: March 30, 2014, 09:50:37 AM »
When you removed the tank there should be 3 hoses,2 go to the petcock(#1 fuel line larger of the 2 and #2 the vacuum line) and one behind the petcock.
Don't think you can eliminate it there is a nipple for it built into the tank.
It could be possible I guess that you put the vac line to it and not the petcock? Which would make the petcock not work properly and be drawing a vac on tank vent . Just a thought. It would be hard to do but possible.
Bota58
« Reply #31 on: March 30, 2014, 10:31:02 AM »
Yeah vaccum is definitely on the petcock and had to stretch bait to get it on,It was one of the new vaccum lines that I put on.
Bota58
« Reply #32 on: March 30, 2014, 10:41:28 AM »
So if the vent hose is not on it really shouldn't affect the running? Because I would still breathe
« Reply #33 on: March 30, 2014, 10:45:09 AM »
It should unless it has something clogging it. Very easy to check to see if hose is there just remove back tank bolt and lift a bit you can see it.
Getting that hose back on is to me the hardest part of putting the tank back on. I have LARGE hands ya see Undecided
« Reply #34 on: March 30, 2014, 10:59:45 AM »
That is the reason I use a long pair with a curved snout needle nose pliers.  I have 2 pair, the other pair is straight nosed.
http://www.amazon.com/Sunex-3706-16-Inch-Needle-4-Piece/dp/B0002NYDR6/ref=sr_1_1?ie=UTF8&qid=1396202258&sr=8-1&keywords=extra+long+needle+nose+pliers
I think the middle 2 are what I have.    I bought  mine seperate at Northern  Tool when they had a tool sale a long time ago.
Bota58
« Reply #35 on: March 30, 2014, 11:38:02 AM »
Yeah I've got a long straight pair and they sure are handy,
Bota58
« Reply #36 on: March 31, 2014, 03:44:52 PM »
I double checked fuel line and it was crimped runs great now,I did check the vent and I was right there was no hose at all so I may have to add one later.thanks for all you're help guys.
Thanks Ron
« Reply #37 on: March 31, 2014, 05:24:49 PM »
Glad it was an easy fix Ron cooldude
Bota58
« Reply #38 on: March 31, 2014, 06:42:15 PM »
Yeah just glad to have her running,gonna ride to work tommorrow !
