November 26, 2025, 12:28:32 AM *
Author Topic: Rear Case Removal Photos.....look familiar??  (Read 934 times)
twdurdentwd
Sebastian, Florida
« on: March 28, 2014, 06:57:11 PM »
lol....not too tech savvy myself
« Last Edit: March 28, 2014, 10:40:54 PM by twdurdentwd » Logged
00' Valk tourer - 6-6, trigger wheel
00' Valk std - complete build
00' I/S salvaged.. Transplant to std
« Reply #1 on: March 28, 2014, 07:06:41 PM »
Only with my eyes closed.    Grin
« Reply #2 on: March 28, 2014, 07:13:39 PM »
You're soooo bad....  Smiley
Hay  Cool
JImmyt
« Reply #3 on: March 28, 2014, 07:14:34 PM »
Yeah......, Yeah.... it does look familiar.  It looks like a polar bear in a white suit in a blizzard.
twdurdentwd
Sebastian, Florida
« Reply #4 on: March 28, 2014, 07:45:54 PM »
lol okay i get it...uploaded
twdurdentwd
Sebastian, Florida
« Reply #5 on: March 28, 2014, 08:02:12 PM »
Here's my personal mechanic who (because of me) has specialized in the Phat Lady...Engine out in 55 mins
twdurdentwd
Sebastian, Florida
« Reply #6 on: March 28, 2014, 10:39:33 PM »
WARNING!! If you encountered a hydrolock in which you had to remove the engine and replace the rear case, you should check a few things:
1) Starter Drive Gear teeth check (this is different than the start idle gear which also commonly breaks)
2) The starter drive gear assembly housing as shown below
   2b. When checking be sure to look at the wear of the dowel pins, also check the bolts for straight-ness as mine were bent.
   2c. When checking assembly housing, also check the actual cast aluminum for breaking around the bolts as shown here in these photos below.
***This "assembly housing" as I referring to..is actually part of the engine block which houses the starter drive gear.***
We are attempting to have these fractures Heliarced
« Last Edit: March 29, 2014, 02:43:32 AM by twdurdentwd » Logged
